Question about Jl Audio 12W7 Car Subwoofer
Tear in foam rim
My sub has a damaged foam rim, how or who can fix this
  • Anonymous Jan 27, 2009
    please help me i have the same problem
    Scholar:
  • 96 Answers
410$ plus shipping to have JL fix it for you or I can sell you a brand new sub with full factory warranty for about $ 475 shipped to your door
JL will replace everything but the magnet and basket and you still wouldnt have a warranty
or i can get you into something better for about 275 - 325 per sub
Posted on Sep 18, 2008
How to fit the foam handles onto the liteway buggie
I tried to remove rivets, no luck. I used WD40 to lubricate replacement foam and slipped it over the big plastic caps. Hard to start but worked well, foam did not tear, all fixed.
Feb 21, 2013 | Chicco Liteway Stroller by
I have a mirage ps12 180 subwoofer and the convex ring around the cone (feels like foam) has a tear in it. Can I use the Elmer's glue and tissue paper procedure to fix it?
Do not use any glues over the foam, it makes the foam get harder and probality of further damage leading speaker replacement. If you have a masking paper tape try to stick on torn area atleast to avoid further damage. But, all this attempts will give a loss on speaker's audio response. If you are not a big audio phile , you can manage doing it.
-kasibhatla
Dec 15, 2010 | Audio Players & Recorders
I have a 13w7 and i am wondering if its possible to find the replacement foam around the top of the speaker. mine has a tear in it and i find it hard to believe that the speaker would be wasted because of...
The foam is molded, you can not remold / repair
If it is a small tear you can repair with a bit of rubber cement. Eventuly it will fail and more will tear causing the sub to sound very bad
Sep 27, 2010 | Jl Audio 13W7 Car Subwoofer
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
My wire got pulled off my sub how can i fix it
Hello gatmanfromda,
I'm assuming you mean the "tinsel" lead going from the connector to the sub cone. In many cases, the wire can be soldered back on. It takes care and patience and you need to be sparing with the solder and prevent it from stiffening the tinsel lead. Otherwise it will tear out again when the sub cones moves out. If the cone itself was damaged when the lead pulled off, you can use silicone sealant to repair it. Again, be sparing with the silicone and allow it 24 hours to set up before trying to operate the sub. If the wire pulled off from the connector terminal, just solder it back on.
Hope this helps.
Jul 11, 2009 | Kicker CVR12 Car Subwoofer
I got a lil tear on the foam under my 12' alpine sub by where the terminals are...how do i patch it up or with wut??
a flexible adhesive like clear silicone adhesive will work, just don't glop it on too heavy or it will unbalance the weight of the cone and shorten the life of the sub. Dont use an adhesive that dries to a hard state or it will actually tear the foam more. Let me know if that helped:) Thanks
Jun 17, 2009 | Car Audio & Video
I have a little rip on the subs ring
The little rip on the foam surround can be repaired easily with some pure silcone from a harware store. Make sure it's pure silicone, because the silicone mixtures may deteriorate the foam prematurely. Also, all you're really doing is plugging the hole that the rip makes so that air doesn't leak out and further damage the surround and also affect your sub's performance. You'll need to apply a thin to moderate coat of silicone to the rip, and make sure that some gets into the rip. Do NOT use globs or big lumps. You should apply some silicone to your finger, and carefully apply it to the area. Try not to get too much on the inside/backside of the rip. If you'd rather just get a replacement sub, you should be able to find the raw driver on eBay or at a local MTX dealer.
May 18, 2009 | MTX RT12X2-200 Car Speaker
Placing sub in box
hi there mate. which foam are you talking about, in the box or on the actual sub? you should be able to remove either to be able to get to the drilling holes. send some photoes if you want to ajd_pimp@hotmail.com and i can have a further look.
cheers,
adam
Nov 09, 2007 | Jl Audio 12W7 Car Subwoofer
Jl Audio 12W7 Car Subwoofer Logo
414 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
