Question about Nokia 3230
Few Keys not working
In my Nokia 3230, few keys are not working at all. Menu Key, Number 4 & 9. I cannot dial the numbers. Contacts cannot be reached as Menu Button is not working
  • manishack Oct 10, 2008
    menu key on my cell phone is not responding.I am unable to see my contacts.
  • Anonymous Feb 28, 2009
    my menu key is not working suddenly.however when i'm pressing it hard it did work,but that too ended in a few hours.
This is what i did when it happened to mine. take your sim card out. put someone else's sim card in. see if it solves the problem. i know its the keys not the sim card. but it was the same problem wiht mine. the 1 button was doing the function of the star button adn 4 was the menu button.
Posted on Sep 12, 2008
My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a white screen appears but the phone does not start. Can you pls offer me a solution for...
well your phone will need full format try this way
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 04, 2010 | Nokia 3230 Cellular Phone
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
Nokia 3230 boot failure or cannot star-up
Do a Full phone formatting following steps below:
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
  1. Green dial key,
  2. * Star key,
  3. no. 3 key on keypad
and then press the power on/off to switch on the phone.
Do not let go the 3 'press and hold' keys until you see a the word 'formatting' is displayed on the screen
Aug 05, 2008 | Nokia 3230
Phone booting
APPLY FLASHING TO YOUR MOBILE:
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be left)
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it).
Apr 04, 2008 | Nokia 6630 Cellular Phone
Not working
RESETTING PHONE BY NOKIA SECRET CODES (steps 1 and 2)
1st step : SOFT RESETTING NOKIA MOBILE
Take backups of ur phone books,calender and others, then simply enter the code
*#7780#
2nd step : HARD RESETTING BY CODE
Just enter the code-
*#7370#
Then it asks for security code enter ur security code whose deafault value is 12345
NOTE:
The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
FLASHING
3rd step :FLASHING : ANOTHER METHOD FOR HARD FULL FORMATTING
This step is known as flashing of phone. Always do this step at last (after 1st 2 steps are over and u are not successfull)
then press the power on/off to swtich on the 6600 phone.
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it)......................enjoy
Regards :
dilipbagdi
Technical Associate
Apr 01, 2008 | Nokia 7610
Backup phone memory
try to format your phone
3. Switch-off your 6600 phone.
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 6600 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Jan 07, 2008 | Nokia 3230
Reprogram my nokia 6680
Full phone formatting on a 6680!
If you encounter situation like below on your 6680,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6680! as steps below,
3. Switch-off your 6680 phone.
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680 phone.
Remember, do not let go all of the keys and hold keys until you see a Nokia turns to white and blink' and nokia logo!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory settting.
Thank you for rating this Tip.
Dec 26, 2007 | Nokia 6680 Handheld
How to reformat Nokia 3230?
*#7780#
*#7370#
NOTE:
FLASHING
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Dec 10, 2007 | Nokia 6600
Nokia 3230 start-up failed
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye sr99mobiles@yahoo.co.in
Sep 11, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Logo
76 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
