Question about Electrolux Refrigerators
Our caravan fridge electrolux rm4206 gets cold on both gas and 240v mains but does not seem cold enough ie freezer compartment is not quite frozen and fridge compartment is not cold enough. Any suggestions? Thanks
Remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Posted on Feb 07, 2009
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Why does my caravan fridge trip out when connected to 240v
The heater element is almost certainly to earth. Work it on gas until you can fit a new heater.
Jul 01, 2012 | Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
The freezer side is NOT freezing, but the refrigerator side seems to be cooling normally. I tried emptying the freezer compartment and setting the thermostat at maximum cold, but nothing seems to help....
Dear customer,
               We recommend you to do the follwoing checks
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak
Click on the highlighted words to know the steps necessary. Thank you..
May 07, 2009 | Electrolux Refrigerators
Our caravan electrolux RM4206 (using mains electric) does not seem to work until we actually get to a caravan site! When it is on our drive plugged into the mains we can't seem to get it to go cold - are...
The Rm4206
has to be dead level to work on mains electric, your caravan may be slightly out of level on your drive.
Put a mini level on top of it and try again.
Apr 09, 2009 | Electrolux Refrigerators
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Freezer freezes OK, frig compartment doesnt get cold
Does the unit only have one compressor (black round object on back of unit). If yes then sounds as though you have lost some refrigerant (just enough to keep the freezer happy). If no (ie two compressors) check if both compressors hot. If both hot then have major problem if one cold then have a thermostat gone. Personally I think you have lost gas from your description, if so then you are looking at a dead fridge freezer. Hope this is of some help.
Mar 13, 2008 | Refrigerators
Refrigerators Logo
891 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
