Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor in sleep mode
My monitor is in sleep mode no matter what i do it stays the same. what can i do? my monitor is a 20' hp wide screen 2007 hp vs17e monitor stays asleep
  • 3 more comments
  • Anonymous Sep 05, 2008
    My monitor goes to sleep every time I reboot. I have unistalled the display drivers, and I can get into the computer. Once I reboot again, I have the same problem. I have to log in with safe mode and uninstall the driver again.
  • donnaleighw Sep 14, 2008
    I'm having the same problem & additionally, when I reboot with the power button, & I get the computer back on, I can use the computer just fine until it stays unused for a little longer than the screen saver time to come on & it goes black & can't get it back - have to reboot.
  • sha7rooor Oct 04, 2008
    same in pavillion 17 inch contineously flickers a going to sleep every 5 seconds
    I searched everywhere no body gives an answer
  • Anonymous Oct 11, 2008
    I'm having the same problem. I went upstairs to take a shower came back down and the monitor was asleep now it's been that way for 4 days. I've rebooted the PC, pressed esc, and nothing has changed! I've only had the monitor for a year!!! I'm so pissed.
  • peaceonearth May 05, 2009
    have you tried turning off sleep mode? IN Vista start -> control panel -> tools to improve performance -> power options then select ..> choose when to turn off display , select never, Try this and see what happens?
My computer is on but screen is black and has power. How can I fix it?
Posted on Sep 13, 2008
    Problem Solver:
  • 6 Answers
Try pressing escape and this will take you back to your desktop
Posted on Aug 27, 2008
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
Hp elite l2201x monitor won't work
I am experiencing the same issue. My monitor will not come out of sleep mode. HP informed me to purchase another power cord, but it yielded the same results. Any solutions????? Thanks
May 28, 2012 | Dell Computers & Internet
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text ever...so.
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
modes in the CONTROL PANEL + POWER SETTINGS>
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
http://pcdied.com/black-screen.html
Jul 20, 2017 | HP w2207 Monitor
Monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
May 30, 2010 | HP 2009M Monitor
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
http://h10032.www1.hp.com/ctg/Manual/c01725831
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
HP monitor staying in sleep mode
I don't know if this qualifies as a solution or not, but to-date, the only solution I have found has been to never upgrade the video driver beyond the original "Spring 2007 Original NVIDIA Graphics Driver", installed via sp26865.exe that I got from HP support when my system was new. This file does not appear to be available now, but the support group may give it to you on special request.
Every time I "upgrade" the NVIDIA drivers, my monitor will not come out of sleep mode and only restoring to the original will work. I do not know if the upgraded driver fixes any of the advertised problems or not since I do not seem to suffer them.
Apr 09, 2009 | HP Pavilion w22 22" LCD Monitor
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
1,104 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
