Question about Ovens
Microwave oven stopped working
Timer works and counts down but micro wave does not turn and turn table does not spin. Fan works. Light works. Is this common? Can it be fixed? Should I buy a new one? Microwave oven does not work and fan does not run, but clock, timer and ligh operate. Door contacts seem to be OK and fuse seems OK since or light and clock operate.
  • 2fineirish Oct 31, 2008
    Same problem. Microwave counts down, fan runs, door locks. However I do not have a turntable in this unit. It is a CM302 upper oven/microwave electric and the instructions say to use oven rack on #3. What can be the problem?
  • 1,543 Answers
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Posted on Aug 28, 2008
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Conbi microwave oven and grill grill and oven working microwave not warming up light on and turn table working as normal
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 05, 2011 | Ovens
I have an oven and microwave combined model # jtp86sfss micro wave will not heat or turn is this a quick fix
Unfortunately, probably not....
Basic
heatman101
Mar 04, 2011 | GE JTP86SFSS Electric Double Oven
Unit stopped working. no microwave or turn table movement, but timer counts down. Any thoughts?
Basic
heatman101
Dec 23, 2010 | Frigidaire Ovens
My microwave 290HS was performing perfectly until one day when it stopped heating. I followed the steps given in the manual. The tray is rotating, the light inside goes off when the door is closed, the...
May be one of the components in the High Voltage circuit has failed...Usually there is a relay or semiconductor switching device that turns on a tube called a magnetron..this magnetron is what heats the food...any one of the components in these circuits could have failed...I would have a repairman look at it to see if would even be worth it to get it fixed.
Dec 20, 2010 | Ovens
There is no heat coming from the microwave part of the oven, although the grill, convection oven, motor, light and fan all work. The 8 amp fuse on the board where the mains cable enters the oven has blown....
Hello, If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.the magnetron i guess is kind of faulty and this is the most expensive part in a microwave oven.
If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
wish yo good luck,
take care.
Jul 19, 2010 | Ovens
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
164 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
