Question about HP Officejet 9110 All-In-One InkJet Printer
HP OfficeJet 9110 Printhead Problem
I believe my printheads are clogged. What's the best way to unclog them? Running the "clean printheads" option has no impact. I've heard mention of somehow using rubbing alcohol and of soaking the printheads somehow. What's the best solution? Keep in mind that the person who had this printer before me never cleaned it or performed any other type of maintenance on it. HELP!!
  • 6 more comments
  • Anonymous Oct 19, 2008
    I have not used this printer for some time and just had to replace all of the ink. When i try to print everything seems to be operating fine but nothing is printing on my pages???
  • cmkagen Nov 20, 2008
    I have the same issues!
    I tried to print and a word document, but nothing prints. I have now used this printer for some time. Please help....I am quite frustrated.
  • Anonymous Jan 15, 2009
    Exactly the same for me too.
  • sexymona Feb 06, 2009
  • Anonymous Feb 16, 2009
    My message says REPLACE YELLOW PRINTHEAD. I soaked it alcohol and still nothing. Is there a printhead cleaning program to run on the HP OfficeJet 9110??
  • fxmn14 Apr 07, 2009
    There is ink in the cartridges, a cleaning run several times won't help, no ink is applied to the paper. Otherwise, machine is running normal, except no print. Will a new print head fix this problem?
    fxmn14@yahoo.com
  • rosworthm Apr 25, 2009
    I have the same problem. I didn't use my printer for quite some time and when I went to use it there was a message stating that the ink was expired. I replaced the ink cartridges and ever since that I have not been able to get any color prints. How do I clean the head?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
This is the official way of cleaning HP print heads. I just totally dissasembled my HP 80 print head, and found that on the inside of the print head there was a giant glob of ink that was between the inside of the print head and a metal mesh filter material. You need to remove this glob, can only be done by opening the cartridge. Good luck, tell me what happened.
Posted on Mar 28, 2010
  • Michael Schaffter
    Michael Schaffter Mar 28, 2010
    The problem is that the printhead is usually sitting in the upright position so all the heavy ink falls to the bottom, just on top of the print head, on the inside. This glob is too big to go through the small print head nozzels. And because ink is heavier than water, all the inks moisture goes to the top of the printhead. If you don't want to dissasemble than turn the print head upside down and put a moist sponge on the print head surface so that all the heavy gunk falls to the top of the print head cartridge.
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
Why does my printer print stripes?
Stripes are an indication of a defective and or clogged printhead. If you use a printer with an ink cartridge that has the gold contacts, clean it with rubbing alcohol. If it does not, run the clean printhead option in the maintenance settings.
Aug 12, 2014 | HP Office Equipment & Supplies
I recently changed my carriage belt.The print quality has ever been so bad.Does not print clear lines,especially with the black ink.Always have some white lines within...Thank you. Nima
The printhead for black ink cartridge could be blocked.
It is better to run the Clean Printhead operation on your printers tools option.
You can manually clean the print head so that next time when you execute the Clean Printhead from HP solution center it will be successful.
First, remove the printheads.
then, pull up the lever at the top of the cartridge holder, this releases the print head.
The print head could be blocked, most common is the dried ink blocking the small holes in the print head.
Washed it in running tap water. It is best if you soak it in a mixture of water and ammonia and leave it overnight.
After soaking, you can spray it with canned air and blow those little holes to unclog it. Once it dry, return the print head and the ink cartridges and performed the alignment.
this video will show you how
May 25, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am getting white lines going through my documents? Does that mean I need black Ink or does it mean my proint heads are having a problem?
hello, yes you will need to replace printhead, just the black/yellow #88 . thats if you already tried going thru the cleaning process.
Nov 30, 2010 | HP OfficeJet Pro K8600 Printer
HP L7680 won't print black, cartridge is new, says it is full, Self diagnostic page says printhead is good
Try printing a Diagnostic page or clean cartridge. Looks like the printheads might be clogged due to low usage or general wear and tear, they may not be working as desired.
Oct 26, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7780...had problems printing, took out the printhead to look at but now the printer says the printhead has a problem, help!!
check the lids from the printhead to the logic board. remove the ink and examine the nostril u could clean it with clean cloth soak in water. then if it persist replacement is best option
Aug 30, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Bad Printhead
http://krakahead.blogspot.com/2009/03/review-of-hp-officejet-all-in-one.html
Place the bottom of the print head on a towel soaked in ammonia for an hour or more if needed. This will unclog it and it will work again. You may need to do this a few times depending on how bad it is.
Also clean all the metal contacts where the printhead attaches in the carrier.
Jan 30, 2009 | HP OfficeJet d145 InkJet Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
1,637 people viewed this question
Seeker5211
Seeker5211
