Question about Panasonic PT-52LCX65 44" HDTV
Light green and pink spots on my hd tv!!!
I have a panasonic lcd projection tv and 1 week ago i noticed a permanet light green spot in the upper middle of my screen size of a baseball and a light pink spot about the size of a golfball on the lower right hand corner! i got this tv in dec 2005 and now its all screwd up! help me my brothers! i have a soft ball size pink spot in the upper right hand corner of my lcd big screen. this tv is only about 2 years old. the main bulb has already been changed about 6 months ago. please help!!!!!! pt-52lcx65
  • 10 more comments
  • grannysee Aug 27, 2008
    my 52lcx65/pt started out with baseball size clouors on it now it outlines everthing on screen plese help
  • Max Fan Sep 11, 2008
    I have seen other postings of this problem and many propose a solution of an eprom upgrade. When I asked Panasonic about this directly, they said they were unaware that an eprom upgrade would solve this problem.
    Are you saying that this problem can be fixed without the help of a technician? Any chance of messing it up more?
  • GPHL Sep 13, 2008
    I have the same problem. It started as one green spot ... now it is several spots ... each the size of a baseball. The spots appear and disappear depending on the color of what is being shown on TV. Does anyone have experience with this suggested fix?
  • guidod Oct 05, 2008
    i have the same problem in the upper right corner i have seen the solution and i thank you but do we know why this happens thanking everyone in advance.
  • wpnstechL Nov 11, 2008
    My PT-44LCX65 has a baseball sized pink spot in the center of the screen. TV is two years old and I replaced the lamp assembly this week when the lamp light came on. the spot is still there.
  • erlidayz Nov 20, 2008
    My 52" PT-52LCX65 hdtv has a blue, red and yellow spots on the screen that began appearing roughly in August, maybe July of 2008.  The only repair alternatives I've been able to find is to have the light engine replaced for a cost near what a new tv would cost.
    Don't understand why the company doesn't step up and take care - GOOD CARE - of customers.
  • wandor Nov 22, 2008
    I have had this problem twice now since I bought the TV just over 2 years ago. Fortunitly I carry a sears extended warranty on it so I was able to make my problem theirs for no additional charge. Last year they replaced the entire lamp engine, very costly. Almost 1 year later it happened again, this time panasonic told them it was a simple eprom update which they did yesterday and the problem is fixed. So the EPROM update does work.
  • shea_468 Dec 01, 2008
    i have the exact same problem. there are red lines and green and blue spots all over my tv and it is only a little over a year and my warranty is up.. is there anything that will fix this because i went back to the store i bought it from and they said that they couldnt do anything..any suggestions
  • Anonymous Dec 10, 2008
    Service Shop just told me that in 80% of the cases, the LSUQ0100 will solve the color spots issue. Sometimes it can be the a damaged circuit. Cost is $175.00 for the visit, and the EEPROM update procedure is usually $150.00 more. However,they said Panasonic is extending the warranty an extra 12 months for this.
    However I purchased my TV on mid 2006, which makes it 2.5 yers old.
    The problem seems to worsen when you crank the brightness and/or sharpness up.
    Lucky me, I purchased an extended 3yr Sears warranty. They'll come in 2 weeks to check it out.
    If you purchase a Panasonic, add the service plan.
  • michiganhitm
    michiganhitm Dec 15, 2008
    Same deal. 3 pink spots, toward the middle-right side of the tv, and going towards the lower right corner of the tv. It gets worse depending on what colors are being broadcast.
  • Anonymous Dec 20, 2008
    i have blue and green spots on my tv and the picture has moved to the lift about 3 in. it's on a pt-52LCX65 52. what can i do?
  • Anonymous Mar 26, 2009
    I have the same problem. Started as one blue spot. I am now the proud owner of four blue spots.
You really need to be persistent. I went on the Panasonic customer support webseite and started a web exchange. The first two attempts ended with "call your local authorized service tech" , etc. The third time, I described the prolem again and asked if the authorized tech would have the tool to fix the eprom if that was the cause of the problem. They finally gave me a name for their scheduling department and said they would pay for the diagnosis. I was pretty happy about that, but even happier when they said that this was a known problem and they would pay for the repair as well. They scheduled a service call. The techs came and fixed the eprom error with their tool within 1/2 hour. That was about 5 weeks ago, and all looks good so far.
Posted on Nov 20, 2008
  • 927 Answers
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Posted on Sep 09, 2008
I had the same problem with the green and purple spots...and the purple outlines on some brightly lit screen scenes but i called panasonic and the sent a technician over and they reset the tv...with a device which panasonic actually sells...(hmm) it was done all free of cost..tv is approximately 3yrs old....tv now works great
Posted on Jan 16, 2009
I had the same problem and based on this forum, I phoned Panasonic service 1-800# and
mentioned the correction tool: LSUQ0100.
Even though my TV was purchased in Feb of 2006 and well out of the warranty, they put up no fuss and sent someone out from a local authorized servicer for NO CHARGE ! My two green spots and one red spot disappeared in 15 minutes.
The repair guy said that this is a design flaw. Not really a 'break'. That is why the repair is free.
Good luck.
I have had a green blotch for a long time and have contacted support. They tied me up with Emails and faxing my model numbers and all that good stuff till they just made me give up. All I got to say is FU Panasonic, I'll NEVER buy another stinking pile of monkey poo TV from you again. I've bought your stuff for years and this has made me sour as hell and totally pissed. YOU try watching a blu-ray with a frickin' green blotch on Neo's face!
Posted on Nov 10, 2008
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
My rear projection TV has color spots in the picture, most noticeable on light color picture
What is the make and model of TV. If it is a Panasonic that has different colored spots such as pink, blue etc. Then you need t6o contact Panasonic as this is a memory reset that they have to perform on the LCD driver board. Other brands of LCD projection sets that have spots that appear all over the screen mostly on white back rounds are almost always dust that has settled on the LCD panels. This requires a technician to clean the LCD panels if possible.
Dec 17, 2009 | Hitachi Televison & Video
Blue and Pink spot on my Panasonic Projection LCD
Panasonic didn't release a 61" LC13, are you sure that you dont have a PT-61LCX65, 35 or 15. If your model ends with a 5, call 1-800-211-PANA (7262) to schedule service, they have a fix fuzzy the fuzzy colored spots they are covering under warranty.
Sep 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Blue & green star like spots on Panasonic rear projection LCD TV
The EEPROM needs to be reprogrammed. You should contact Panasonic customer care as they may fix this at no charge to you.
Jul 07, 2009 | Panasonic PT-50LC13 50" Rear Projection...
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
(Yes, this is a cross-post from another thread...I just wanted to help everyone on the various threads on this issue...please do not flame me)
Ok...once and for all I will explain the fix (in detail...which has been missing)...
1) Firmware updates do not fix this problem. I had this problem, and updated my firmware to the latest versons without success. Also, cleaning the light engine (or any other part) does not fix this problem. If you cleaned your TV and your problem disappeared, you had a different problem.)
2) This repair requies a special tool from Panasonic. The tool is part number LSUQ0100. It is light grey in color, and is roughly 7" x 5" x 1" in size. It has diagnostic lights on it, and a button to press to start the procedure. This tool is used to reprogram your EEPROM. Again, this is VERY different than flash upgrading your firmware.
3) To repair the TV, the repairman must remove the lower back of the unit and plug the long, 5-wire connector (5 individual wires terminated to one female connector end - reminds you a bit of an old-style CD-ROM audio cable used in computers) into a male recepticle on the light engine.
4) The procedure takes roughly 6-7 minutes to complete. The TV remains on during the procedure (yeah, I was a bit surprised too). About mid-way through the procedure, your colored ball-shaped blotches will just disappear....no on-screen progress bar, no bright flash, the spots just disappear in the blink of the eye.
5) CALL PANASONIC!!! They are standing behind these TVs, and are covering these in-home repairs free-of-charge - EVEN IF YOUR TV IS OUT OF WARRANTY. Mine was out of warranty by over a year. The Panasonic rep was very kind, but did explain that this is the only repair for these TVs that they will cover out of warranty, as it was a defect in the manufacture of the unit - all other repairs are at the expense of the customer.
Good luck to all - I hope this helps some of you!
Cheers to Panasonic for standing behind their products like this....you don't see that very much these days!
Thanks,
Chris
Sep 25, 2007 | Panasonic PT-44LCX65 Television
Panasonic PT-52LCX65 44" HDTV Logo
2,347 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
