Question about NEC Electra Elite DTU 16D-2 Corded Phone
Phone ringer is too loud
There is this loud ringer on my phone how can i turn it down?
It was a low ring before then i came back from being sick and now its really loud
  • Anonymous Mar 18, 2014
    My phone rings continually even with the handset down and the only way to stop it is to turn the ringer to off . What can ido
WHILE the phone is ringing, push the down arrow key.
Posted on Oct 02, 2008
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
I have a NOKIA 2610b go phone, How do you turn up the volume on the ringer?
I've worked in the cell phone industry for many years. The big Nokia phones is that most of them never ring very loud. The have a history or blown speakers when they have loud ringers.
Try going under Profiles and changing the ring to outdoors. that will make it ring louder but probably still not loud enough
Oct 13, 2009 | Nokia 2610 Cellular Phone
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Jul 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Turn off ringer
No specific knowledge of your model but I have seen many people place tape over the housing holes for the ringer to cut down the volume level on phones where the ringer is too loud.
Jun 14, 2007 | Southwestern Bell GH-5812 Cordless Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
233 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
