Washer runs an extreamly long time. I do use HE wash liquid. I put it on 25 min quich wash and check on it 30-40 min later and it has 125 min to go??????????
Does your washing machine go to rinse or spin? If it does not there is a problem with the in bulit in heater. Please check underneath. It is possilble that the heater is faulty or a wire has come lose.
Posted on Aug 27, 2008
How do I get my clothes to SMELL like clean clothes? Darn washing machine stinks them up!
Check the drain where ti empties into, smell the drain thats most likely where the odour is coming from.
Aug 18, 2014 | Maytag Centennial MTW5800TW Top Load...
Need manual for whirlpool front load sport duet model wfw8600sr00
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged / kinked
Unplug washer/disconnect power
Check electrical connections to pump and make sure pump runs, check drain pump filter for strings,sand etc., plug in washer. If this don't work dismantle pump carefully to check if anything is clogging it. If the electrical side of pump is faulty this can easily be replaced, it is normally not repaired.
Washer parts can be found on this site.
www.youtube.com/watch?v=2abTptUYXH8
Mar 04, 2013 | Washing Machines
HI I HAVE A GREAT ILIVE INTERGRATED DISH WASHER, BUT NO MATTER WHAT SETTING I PUT IT ON TO WASH IT WASHES FOR 88 MINS, IT DID NOT COME WITH A BOOK AS IT WAS LAST ONE ON SALE CAN YOU HELP WHAT DO I HAVE TO...
Is your display faulty?
Does the timer count down?
Does the run time of the dishwasher change even though 88mins is displayed?
if all else fails run the dishwasher from a plug in timer, turning it off after 25 mins :-0
Dec 17, 2010 | Dishwashers
My zanussi washer dryer has some problem When i set a program and lets say the program is 125 min it finishes after 40 min and it is not spining.Also when I try different programs I have the same problem
check the drain filter is not blocked if it does not empty all the water it saves time on the next fill. also the spin will not happen if it has not emptied completley. a faulty pump would give the same effect.
Nov 05, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
F-21 error means What?
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Instruction manual
Option B is the standard option for whites and colors and is approx 125 mins long. Option A adds a 25 min soak. Option C/D is the short cycle at 70 mins. I haven't figured out how to program an extra rinse yet.
Apr 18, 2009 | Washing Machines
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Wash cycles far too long!
you may have the hot and cold hoses connected wrong way round. water flow from hot is often very slow hence the extended times. to check, put on rinse which should let cold water in. see if it is in fact hot water coming in and this confirms hoses wrong way round. just interchange them. smell could be due to using liquid detergent. change to powder type
Jul 05, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
