Question about Pantech Duo Smartphone
Bluetooth head set
I have the same problem as already eplained... when i try to add my headset to the pantec duo it states 'no devices were found...'. It does not have a place to add any kind of code.
    Problem Solver:
  • 11 Answers
Also make sure your bluetooth is on, sounds silly i know but your phone will still try to look for a device even though the bluetooth isnt on so check your connections and see if its on.
Posted on Sep 21, 2008
  • 3 Answers
I had the same problem before. Its probably your blue-tooth they have to look for your phone while its looking for the blue-tooth. You need to look in the blue-tooth handbook and find out what butons you have to push to get it to look for the phone...
Posted on Aug 29, 2008
How do I turn on the bluetooth
On the cellphone menu there will be a set of preferences and settings for Bluetooth. Scroll through the menu options. Make sure the headset is on. The phone should list the detected devices. Activate it from that menu.
Nov 25, 2014 | cellphoneshop.net BH29 Boom Mic Bluetooth...
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
LG Rumor cannot bluetooth with headset
To pair your phone with another Bluetooth device, perform the following steps: 1. Press the Menu/OK key, select Settings/Tools, select Tools, select Bluetooth, select Add New, and then select Search. Your phone displays a list of discovered in-range Bluetooth devices. 2. Select a device, and press the Menu/OK key. 3. Enter the passkey, and press the Menu/OK key.
http://support.sprint.com/doc/sp10800.xml?selectedDeviceId=9207&related=y&Referring%20Related%20DocID%20List%20Index=1&navtypeid=6&pagetypeid=7&prevPageIndex=8
May 04, 2009 | LG RUMOR Cellular Phone
How can i pair the just wireless bluetooth headset with my phone
with the headset off, press & hold the power button for about 9 seconds until the indicator light alternately blinks red and blue. Set your phone to search for a new headset or bluetooth device. When it finds the headset, the passcode shoudl be 0000
Feb 27, 2009 | Just Wireless Bluetooth Headset Wireless...
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Im trying to pair my verizon cell phone to my motoral headset
6) You will be required to enter in a pass code which is standard ‘0000’.
Hope this helps
Chris (ziraffa)
Bluetooth won't connect
follow the steps below:
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 24, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Winamp/bluetooth/plantronics p590
I have found that winamp doesn't automatically output through any hands-free headphones, therefore you need to go into Preferences on Winamp (Ctrl+P), go to:
-Plugins/Output
-select Nullsoft DirectSound Output -->configure
-select Device tab
-select 02: Bluetooth Hands-Free Audio
-click apply
If music is already playing, click STOP then PLAY, pause will not do it.
I have been looking for this fix all day on the internet, but finally worked it out myself.
Hopefully this post will make someone else's day less stressful!
Nov 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Bluetooth
Sir
1st tap on start .
2nd tap on settings.
3rd tap on connections.
4th tap/select bluetooth Icon.
5th tap on mode there mar both Turn on bluetooth & Make my device visible to others.
6th add new device.
7th u will see the name there of ur bluetooth device / Headset.
8th select the one wch is ur.
9th enter a pass key 0000
10th make ths device authorised and connect to headset
TRY it and mail me soon
at ( lovedeepsingh_35@yahoo.co.in)
Jun 29, 2008 | AT&T 8925 Tilt Smartphone
Setting up my H350 on a new phone
when hooking up your bluetooth hold your volume and your call button at the same time. .then your head set indicator light stays on .then you can set up your phone,your phone will ask for a code the code is 0000 that will set your headset to your phone.
Sep 18, 2007 | Motorola Mobility H350 Wireless Headset
Pantech Duo Smartphone Logo
52 people viewed this question
Top Pantech Computers & Internet Experts
Jax Planet
Jax Planet
Ben Darden
Ben Darden
Trisha
Trisha
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
