Question about Toshiba 27D46 27" TV
When I turn on the TV with the remote or on the front, it comes on for a second and then shuts off. I was able to keep it on once, and all I got was a horizontal white and colored line across the TV, but then it eventually shut off.
  • 148 Answers
Horizontal lines indicates that the vertical section is most likely the defect..a defective deflection yoke could cause this and eventually damage the vertical output ic causing an overloading in the power supply then can caused to shut down
Posted on Jul 16, 2011
SOURCE:
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
Cannot remember how to program remote
Turn the TV on, press and hold the CODE SEARCH or SETUP button until the light light comes on,then release, press TV button,the light will blink once and remain on, press and release the POWER button until the TV turns off, wait two seconds and keep press the POWER button until it turns off every two seconds,once it turns off press ENTER or SAVE...hope this was helpful...
Apr 21, 2010 | GE RM24970 Remote Control
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive.
The problem is most likely a short in the switch panel on the front of the TV. The remote won't work because the TV thinks that you are using the manual buttons on the front, and the manual buttons override the remote. Have the front button panel replaced....it's under $200.00 - or you could solder the switches apart and just use the remote.
Nov 01, 2009 | Toshiba 36A43 36" TV
I have an older tv remote that requres a 3 didgit code the tv is a zenith and so is the remote
here is how you retrive the code...make sure tv is on
Step1..press and hold code search button till light comes on then release
Step2..press the TV button once
Step 3.point the remote at TV and press and release the power button while pointing at TV((you may have to keep pressing the power button several times)) once Tv shuts off hit ENTER
Step4..Press TV button on remote and there you go!!
GOOD LUCK!!!
May 09, 2009 | Zenith DBZN-311 Remote Control
TV keeps changing channels
Out of 30 years in the repair field, I have seen this problem maybe 4 times. Once was a stuck button on the keypad of the tv. The other time was a second remote control with a book sitting on it and it would turn the tv on and off when someone would move something on the coffee table, another time was a bad solder connections on the microprocessor on the keypad circuit board and the last time was from a humorous neighbor in an apartment complex who thought he was funny who had an all in one remote control programmed for his neighbor's tv set.
Oct 03, 2008 | RCA P52921 52" Rear Projection Television
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Toshiba 27D46 27" TV Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
