Question about JVC GR-D250 Mini DV Digital Camcorder
Jvc camcorder camcorder stuck in safe mode 01
  • 1 more comment
  • lasserre Dec 12, 2008
    My JVC GR-D240E is stuck in Safeguard mode. How can I fix it?
  • someone here Jan 25, 2009
    Same here
  • Anonymous Jan 31, 2009
    Code E06 unit in safegard mode remove and re-attach batteries
I bouht j.v.c handycam recently, unfortunately lcd screen is broken what is cost ?
Posted on Aug 28, 2008
Stuck in safe mode. error code 01. please help
This is what is called a mem lock-up and to escape you need to press reset, though you will need to set up the clock etc again.
Jun 15, 2010 | JVC GR-D270 Mini DV Digital Camcorder
JVC Camcorder Error code E 01
Your camera can not load mechanism completely(E01). Could have problem with mechanism or the mode motor itself fails. By the way, serial number is not necessary. Good Luck
Mar 20, 2010 | JVC Cybercam GR-DX95 Mini DV Digital...
Eo3 safe mode
Problem with reel, could be your cassette causes the problem.In case your cassette stuck, eject the cassette by applying power on it and keep cassette door open for 5 sec or more until cassette ejected, then use other cassette. Otherwise have it check by the expert. Good Luck
Mar 04, 2010 | JVC 580136 Camcorder
My camcorder is stuck in safe mode
I need to know more details about your problem, error code follows numeric code. Such as 01, 02, 03 etc. you need to consult an expert. Don't force the mechanism for it will cost you more to repair.
Feb 27, 2010 | JVC GR-DVL500 Mini DV Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Safe gaurd
Safe gaurd mode can mean a number of different problems, most of the time being mechanical, if you are not a tech. you will need to take it in for service.
Aug 09, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Getting e01 message what to do
http://www.fixya.com/support/t103751-in_video_mode_error_code_message_e01 resolved it for me... Apparently the JVC cameras have a little button that detects the presence of the battery, but it doesn't move very freely and you really have to slam the battery onto the camera before it notices. Cleared my E01 fault first time after having been getting more and more frustrated since it first locked up
Chris
Dec 22, 2007 | JVC GR-SXM265 S-VHS-C Analog Camcorder
Camcorder stuck in E02 Safemode
hey have the same problem with my camcorder too far the past 3yrs send it to jvc they said no problem found but as soon i got it back it work for one day them went back to safe mode.they said they could rplace the head mechanicalism for $350 which is roughly what paid for the camcorder.if gotyours fix let me now
Jul 15, 2007 | JVC GR-SXM260E Camcorder
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
124 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
