Printer (2410) is unreliable when the last two sheets slip up together. This is also a problem that messes up much paper and wastes ink when doing two sided work. I have to do the one side and all is well. I turn them over and invariably somewhere in the middle two slip together and the pages are out of order for the rest of the work. I must repeat disgustedly the messed up pages and go one by one. Tom Roach tlchosen@eastlink.ca What can I do????? If anything. Switch to Cannon?
  • 1 more comment
  • tlchosen Aug 27, 2008
    First of all my problem is not addressed,it has nothing to do with television. Please send this to the proper department. To tell me to look at the manual is useless as it does not address ths said problem of poor printing on the 2410 printer. you need to get a warm body on the subject. PLEASE. Tom Roach
    Please; my problem has nothing to do with television. My question has to do with my HP printer. I have already told you that problem .If it has slipped through the cracks, let me know and i will repeat it. IF NOT PLEASE REFUND MY MONEY!
    respectfully, Tom Roach
    If I must insert paper one by one I will go get a Cannon printer. they can print more than one page without taking two sheets and messing up the sequence when two siding.
    This is NOT a satisfactory answer.!!!!!
    Tom Roach
    Master:
  • 521 Answers
In your printer where you feed the paper is called the paper feeder tray.in that tray in the lower area there are two small gears on both the sides.just clean that gears if some dust is blocking them .and check whether the gears are cracked you have to replace them.you can replace it with new as they are not to costly .they are called as paper feeder gears.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 27, 2008
    Master:
  • 848 Answers
There is a solenoid on the right side of the printer which stops the toothed gear. You can see this if you open the printer cover exposing the inside of the printer. On the solenoid there is a thin piece of foam which becomes sticky with age and temperature inside the printer. When the second and subsequent pages are printed, the solenoid the metal flap sticks to the solenoid and hence the timing of the feeding of paper is messed up ........
  • 435 Answers
The cause for this problem is worn out pickup roller and separation pad fail to properly grip paper, causing paper jam.
Check this link for more details:
http://www.fixyourownprinter.com/kits/hp/K30
Thanks
  • 10,594 Answers
Please let me know is it desk jet printer type? If yes, then in my opinion, 2 papers got stitch together due to humidity in printed ink.
  • Shahid Electronics
    Shahid Electronics Aug 27, 2008
    oops, please ignore my previous message as I just saw its laser printer. HP 2410 laser printer. Really sorry.
    President:
  • 1,952 Answers
U just insert a paper one by one ...else keep the first paper a few inch ahead of rest paper...this pro may cause due to over air pressure in a roller..
    Sergeant:
    Champion:
  • 310 Answers
See the manual...
  • khader ibrahim Aug 27, 2008
    Check the guide also.
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation....
Extra download =====> Fix_ip1000_InkOverflow
on Jul 29, 2010 | Computers & Internet
Tip
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
turn off printer.
- press and hold your finger at on/off with reset/stop button together
- release the button on / off, but at the same time continue to press the stop / reset and then press the button on / off again and continued to hold the two buttons.
- wait a moment
- relese stop/reset button 2X.( you will see the led light blinks twice when you press the stop / reset twice)
- release on/off button.
wait until the screen on the printer control panal shows the number 0.
- press stop/reset button 4x
- wait until you hear the movement of your printer roller
- when you hear the movement of the roller your printer, wait a while until you do not hear any sound of movement in your printer. :)
- turn off and turn on printer again and your will see your printer back to normal.
Ok world...Good luck
------>>>Download guide to fix waste ink overflow ip1000 Click Here
on Jul 21, 2010 | Computers & Internet
How di I reset my Pixma printer MP150 from
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
First way
turn off printer.
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Tip
True guide to reset ink tank absober full on canon mp140
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
turn off printer.
Thanks.
Extra download ====> Fix_IP1000InkOverFlow
on Jul 16, 2010 | Office Equipment & Supplies
Tip
Hello worldvet, the cleaning of the waste ink absorber in the W7200 from Canon...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Aug 31, 2008 | HP Officejet 5610 All-In-One InkJet...
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
I just replaced all 4 ink cartridges on my epson stylus c84 printer. The 2 left buttons on the printer are flashing and it will not print. I have tried turning it off and then on but it still won't print....
See the on-line handbook
http://support.epson-europe.com/onlineguides/en/sc84/index.htm
and look in Problem Solver, Diagnosing the Problem, Error indicators. If the two lights are flashing together, you have a paper jam. If this is the case, you should be able to pull the paper out from the front or top. If the lights are flashing together, and you can't see any paper jamming the printer, post a new comment to this effect for more help.
If the lights are flashing alternately (Unknown printer error), it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you should change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment and I will provide further help.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Canon Pixma MP 610 Pixma Printer
hi dear
this the error code
Direct Printing
E22 Carriage error
E29 EEPROM error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
