Question about Frigidaire GLEQ2152ES Electric Dryer
I get an error when drying. it states "ad" on the timer part please help
I recieve the same problem and i havent even used my dryer much, i bought it last may 2007 but have maybe used it 3 or 4 times because of a house renovation project. i tried the main breaker switch on the how bust still the problem persists where it runs and never warms up and after a while it will stop and display Ad and the four blinking lights next to it. Please help
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Do you clean your lint filter every load?
If the vent is blocked it will not get hot either!
Check the outside where the dryer vents out and be sure the outside screen that keeps small animals out is not clogged!
Even half way cloged will stop the drying process!
Other wise this is a situation that you will need to call service!
Now you can call the manufacturer and tell them even though
its after the warranty that you were building a home and not used it till last week!!!
Ask for a supervisor an tell them you did not purchase you stainless steel kitchen yet and must be sure they honer their workmanship first!
I use this for my customers all the time to get things done for them! It will work if you are calm quiet and persistent!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
Ad error code
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Error code AD error code DN
it means auto dry it will check the temp of the clothes so if they dryer quicker then 40-45 minutes it will shut off earlier instead of running the full 40-45 minutes. In the manual it says AD is the adjusting time according to moisture level for those who keep drying but display this it is normal for those who display and size to dry is not normal if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
My Frigidaire dryer has an error code of AD and is taking forever to dry our cloths. Please help.?
Hi
Thanks for using FixYa. Error code AD means air/auto dry. This type of dryer has no thermo fuse which is a fuse like part that tends to break disengaging the heating element, there for the dryer has a busted heating element, you’ll need to replace it then it should be good to go. Normally runs parts and labor about 150. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 28, 2010 | Frigidaire Dryers
Dryer heats &revolves but clothes do not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
if this helps please vote me a fix ya
Jul 15, 2008 | Maytag Dryers
Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Maytag Dryers
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Error "AD" when drying
thats not an error code error codes are f codes eg. f01 f02 thats a cycle code for auto dry are you having any promblems other than the display
Mar 26, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
111 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
