Question about Amana Refrigerators
Have Amana refrig with bottom mounted freezer Model ARB2217CW. Noticed the last day or so it makes a buzzing noise--almost like an electric shaver then it shuts off with a click. Today items in freezer where beginning to thaw. Any idea if what this is?
  • 1 more comment
  • whatthe1 Nov 17, 2008
    Off and on buzzing. Stopped for about a month after cleaning under the fridge. Now back again. Dx by repairman as a bad condenser but I'm sceptical.
  • Anonymous Mar 18, 2009
    buzz @ the beginning of the cycle when it first comes on and then it goes off with a click.
    pollyluvpat@hotmail.com
  • mrgpotter May 19, 2009
    I heard a clicking sound intermittently then the next day I noticed the items in the freezer were not frozen.
See the post by lola77 with the same complaint. We have an Amana top/bottom freezer and are having the same problem and we've only had it 4 1/2 years. First service call available that the 1-800 number gave me was 3 days from now, which is ridiculous.
Posted on Oct 23, 2008
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Amana ABB222DE is the overload/capacitor the same thing as the compressor relay? I just had the compressor relay replaced in amana bottom mount. Frig cools fine but every 2 days or so buzzing noise...
I have been doing refrigeration for over 30 years and I have never seen a compressor with a chip inside of it. Have you tried cleaning the condensor coils? I almost sounds like you have a weak start capacitor. Let me know if i can help you any futher.
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerator has stopped working. Model # ARB2217CW, Ser# 11194157CX.The lights are on the fan is working.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Amana ABB1927DE Bottom Freezer...
I moved into a house a week ago and have noticed that the bottom freezer Amana refrigerator makes a grinding, humming, clicking noise constantly. I seems to be getting worse each day
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Aug 25, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Model number ARB2217CW Amana Refrigerator Bottom Freezer. The freezer is working fine but the fridge has stopped cooling. No strange noises, no frost, no water leaking--just not cooling at all.
I would check the circulating fan. This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and the frig.
Aug 01, 2009 | Refrigerators
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Freezer lower basket: how to get a replacement part not available in Canada
I can't find a cross reference that shows avalible. The lower basket part number is 67001240. I would try a web search for that number some still has it in stock somewhere.
Apr 18, 2008 | Amana ABB1927DE Bottom Freezer...
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Refrigerators Logo
481 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
