Question about Canon PIXMA MP470 All-in-One Printer
Memory stick adapters
I just purchased my Canon MP470 printer on Sunday and it will not accept my Memory Stick Pro Duo adapter? Does this printer accept the adapter or just the memory card?
  • 2,039 Answers
According to the user guide, the Memory Stick Pro Duo requires an adapter. With the adapter attached, it should fit into the right-most of the two slots.
Posted on Aug 27, 2008
I need a sd card and cable for sony f 717
Your Sony uses a memory stick called Sony Memory Stick Pro which they don't make any more, it was replaced with a smaller card called Sony Memory Stick Pro Duo, go to ebay and buy a adapter called Sony Memory Stick Pro Adapter it is sliver in color with blue color at the end. Once you get ahold of that adapter, you can now buy the new smaller card called Sony Memory Stick Pro Duo and insert it to that adapter, then slide the adapter with the new smaller card into your camera.
I have several older Sony digital camera that I converted to use the newer Sony Memory Stick Pro Duo cards, it works great ! I checked your Sony model on Ebay and you have to scroll down a bit to see those adapters I just mentioned, some sell with the adapter and the newer memory stick already included in the price.
Oct 06, 2014 | Sony Cameras
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
My printer wont upload my memory card photos,
These are the compatible digital memory cards for your Lexmark X8350 printer:
CompactFlash I & II
SmartMedia Card
Microdrive
4 Built-in Card Readers
xD Card
PRO Duo (
Sony Memory Stickwith adapter)
May 13, 2011 | Lexmark X8350 All-In-One InkJet Printer
Does the canon pixma mp 500 printer recognize sdhc memory cards?
No, it doesn't support SDHC, the following card types are supported by Canon MP500 :
CompactFlash®, Micro Drive®, SmartMedia®, Memory Stick®, Memory Stick Pro ™, SD Card™ and MultiMediaCard™
And these are the cards which can be used with respective adapters:
xD-Picture Card™, Memory Stick Duo™ Memory Stick Duo Pro™, miniSD™ card
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 17, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
    This error code is for Memory Stick. the Countermeasure are :
Format the “Memory Stick” or internal
memory.
CAUSE :
“Memory Stick” or internal memory is
unformatted.
Thanks for using fixya.
May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Stick Micro M2 Memory Card
Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
M2 to memory stick pro adapter
Plug the duo card into adapter labels need to face same direction. Plug adapter into camera or other device label facing you. Once card is installed make sure you format it for the device. My memory stick is 8GB and I use it in my P200 cybershot camera. 2400 high quality 7mega pixel images and 42min-3hrs of mpeg video.
Sep 09, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Memory card
video on cnet
and
look at the right side of paper tray two card slot just here ^.
Support Media
CompactFlash®, Micro Drive®, SmartMedia®, Memory Stick™, Memory Stick Pro™, SD Card™, and MultiMediaCard™.
The following can be used with a special adapter sold separately: xD-Picture Card™, Memory Stick Duo™ Memory Stick Duo Pro™, miniSD™ card.
hope it helps.
Dec 02, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP470 All-in-One Printer Logo
64 people viewed this question
old marine
old marine
