Question about HP LaserJet 3052 All-In-One Printer
Paper size Is there a way I can change the paper size when I scan it. I would like to get 8 1/2" X 14" as well as 8 1/2" X 11'.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If it's in the doc feeder it doesn't need to change size only when on glass or if the paper is in the tray.
1-change in the menu of the menu of the printer
2-go to Settings then printers and faxes on you pc then right click on the printer goto properties, then device settings and change there.
Posted on Aug 27, 2008
HP Photosmart C309a default scanner paper size
Hi Norman,
Are you trying to scan from Printer to PC or Activating SCan option from PC ?
On your PC, Open Solution Center
Click on Settings option below
You will find Scan document options - select it
you will find the Size of paper set, Change it to Letter
Regards,
Sean
Jan 31, 2013 | HP Photosmart Premium C309A All-In-One...
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I am using Omnipage 17 through Microsoft Word 2003 wth an HP scanner. I am scanning text. The default page setting is for legal size paper, and there is a long list of paper sizes one has to scroll through...
Linda I suspect you can open a template called normal.dot and change the paper size then save the template.
see
http://www.geekstogo.com/forum/topic/131676-change-office-word-default-paper-size/ - the second answer given ..
Dec 09, 2017 | Nuance Communications Omnipage 17 Pro
Scanner not scanning right. scans in sections. i need to scan a standard size sheet of paper and it scans it in peices. how do i get it to scan this document correctly
You need to set the scanner to scan a standard size paper (letter or A4) in the Scan Settings dialog. To get there, from the MP Navigator select "Scan Photo/Document", then on the lower left side of the preview area click on the "Specify. ." button. Your Document Size is probably set at "Auto Detect (Multiple Documents)". Change this to the size document you are scanning and click "OK". Now you can preview and scan and not have segmented images.
Mar 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Jan 07, 2010 | Ricoh Office Equipment & Supplies
Unable to scan a4 size paper
Check the default paper type for your scaner, change the paper size to A4 and try the can again
Dec 29, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Scanning legal size documents
Using SCAN feature of Paper Port software - (after clicking SCAN button ... select Define under Options section of the window ... the option to select paper size then exists). With harmony.
Jan 28, 2008 | Xerox DocuMate 262 Path-Through Scanner
Scanner
plz help me to understand: waisting paper by scanning?????
There is no paper to waist!
The machine scans the whole glass! The settings for scanning can be set by the scan software. Do have a look there. It might be that the settings auto crop the size.
In case you run copy do change the paper size.
Jan 22, 2008 | Brother MFC 420CN All-In-One InkJet...
HP LaserJet 3052 All-In-One Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
