Question about HP iPAQ H6300 Pocket PC
Series Back Light
My Backlight suddenly has gone and the screen is really Dimm. Any Ideas? Have checked all the settings.
    Master:
  • 450 Answers
It is possible that by holding the power button down too long, that you turned off the backlight. When you hold down the power button, a menu eventually comes up with "Backlight Off" highlighted. The easiest way to undo this, is to simply do a soft reset. Or, you can hold down the power button again, and "Backlight On" will be highlighted (if there's enough ambient light you can see this message); just tap it, and the backlight will come on again. Also check out your backlight settings by tapping: [Start][Settings]tab[System][Backlight] the tab [Battery Power] should be highlighted; adjust as desired. Next tap the tab [External Power]; adjust as desired. Finally, tap the tab [Brightness] and make sure the sliders are high enough.
Posted on Sep 07, 2005
Why has my LG tv suddenly gone dark
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 07, 2014 | LG 37LH3000 37" HDTV LCD TV
Screen dull on Janome mc 8000
There is an LCD Backlight Panel that illuminates the screen, and yes, they do fail.
Before you start, just check the screen contrast dial inside the top cover, front right, they can be easily knocked and this will also cause the screen to go light or dark.
Janome no longer supplies the LCD Backlight, however, we have an after market replacement at our store, and also provide fitting instructions and a good deal more besides.
If you care to contact me I can send a Diagnostic Routine and the Screen Reset instructions for you to check if there is anything else causing troubles.
Please remember to give details of your dilemma as we do receive a lot of requests.
Contact Link
Cheers
Martyn
May 15, 2010 | Janome Memory Craft 5700
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
Acer 5810t laptop. screen gone black
Press and hold the Power button for 45 seconds to turn the laptop off.
Then, remove the battery from the battery compartment and clean the metal contacts.
Next, reinsert the Battery and try to turn it ON.
If the display still doesn't come then you may try connecting an external display to check if the Computer is able to produce display and the issue is with the backlight of the LCD screen.
wish u good luck!!!!!!!!!!!
Sep 17, 2009 | Computers & Internet
Printer LCD Screen is on but blank
First let me know if there is backlight on printer control panel or not.
If there is no backlight on printer control panel than May be LCD Control panel is faulty or it is not recieveiving power from DC Controller.
If there is back light than try these steps.
Try to reseat the Memory DIMM of the printer
If u have replacement of DIMM than try that .
Or else formatter is faulty.
Need to get formatter replaced.
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hitachi rear projection tv turned off, won't come back on
Hitachis have a series o led's on the main board, mabe up to six, thesshould all light up when the set is on, o frst thing is to lookat thes LED's and see if they all light up
Jun 24, 2008 | Hitachi 50UX57B 50" Rear Projection...
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Feb 17, 2008 | Televison & Video
HP iPAQ H6300 Pocket PC Logo
314 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
