Question about Gateway DLP56TV 56" Rear Projection Television
Turn on TV on power up the LED's in front flicker bewen amber red and green and does not turn on, it pauses and tries again. It takes some times 10 to 30 minutes to turn on. But other times it turn on OK? What causes this problem>
  • 1 more comment
  • Justino Garavito
    Justino Garavito Sep 02, 2008
    Thank you for your help, I tried and some times it works....
    But there is a problem with the power up.
  • ktranzow Nov 10, 2008
    I have the same problem. Lights flicker but never powers up. It use to work by unplugging and waiting for a few minutes. But now that doesn't work. Any suggestions?
  • mssamoa9 Mar 22, 2009
    power and lamp light keep flickering back and forth. tv will not power up. we tried unplugging power and that wont work either.
  • 15 Answers
Your lamp life is most likely at the end of its life - you need a new one, make sure you get the right Osram one (I think they are as little as $120 or as much as $200). Replacement is fairly straightforward (15 minutes).
There is a compartment in the back with two screws.
Unscrew lamp enclosure inside
Pull out enclosure
Unscrew wires from bulb
Pull wire clamps off of each side of bulb with pliers
Remove lamp and replace with new one (note orientation and do not handle the front of the bulb)
Posted on May 01, 2009
  • Richard Bozzell May 01, 2009
    BTW - to confirm that this is the bulb, count the number of green flashes to amber ones:
    Green x 2, Amber x 1, Lamp LED off - Cooling Fan failure
    Green x 3, Amber x 2, Lamp LED flash - Lamp Failure
    Green x 5, Amber x 2, Lamp LED off - Hardware failure (more serious analysis required).
Unplug it from wall, wait 1 minute, then re-connect and power up.
Posted on Aug 27, 2008
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
3 Reset System
From the remote, press
<MENU> <1-2-3>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
All customer settings are
reset to factory default.
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
REGZA 47HL167 TV is difficult to turn on. when powered on the amber lite flashes 3 times then pauses for 1 second then repeats the 3 amber flashes. If I keep pushing the power button on the side,...
3 flashes of the led light at the front panel is means that the unit is in booting process. The symptoms you've mentioned is caused by faulty electrolytic capacitor in the power supply section.
Look for faulty capacitor with bulged, dome at the top and then replaced it with same ratings. If you have a capacitor checker, it will make you more easy to identify the faulty capacitor without a physical indication of fault.
Oct 07, 2011 | Toshiba REGZA 47HL167 TV
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Gateway DLP56TV 56" Rear Projection Television Logo
332 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
