Question about Sharp AR-M160 Laser Printer
AR-NB2 Dear experts; If I purchase the AR-NB2N Expansion Kit in Canada, is it the same as the in European version and will it work on my European AR-M160? Do I also need the AR-NB7 or will it Network without? Is there also a compatible DIMM that I may use instead of the AR-SM5? With the above, is it possible to print from a MAC (OS 10.3) without the PS Software (pdf for example) ? Look forward to recieving your help. Kind regards, Kirk
  • Mr Yellowbelly Aug 27, 2008
    Dear experts;
    European AR-M160?
No I havn't to date, but I understand you also offer a free service.
Please inform and thank you again
Posted on Aug 28, 2008
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
My Sharp AR-M160 will print but not copy. No problem buttons are lit up but just dont work.
have you got the machine on print mode
if you find the button that says print copy fax on it press it until the light is on copy...
hope this helps
Jun 18, 2010 | Sharp AR-M160 Black and White Copier
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? http://www.jvc-victor.co.jp/english/car/support/navi/nt1/eu/index.html Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
Nov 28, 2009 | JVC KW-NT1 Car GPS Receiver
I WANT A PRINTER DRIVER FOR SHARP AR-M160
follow the link below:-
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
plz rate the solution...
Nov 14, 2009 | Televison & Video
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
Nov 10, 2009 | Sharp AR-M160 Laser Printer
I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
Jun 11, 2009 | Sharp AR-M205 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
Good Luck
May 30, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
240 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
