Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
My comptuer reboots when I isntall the software
After Installing My Camcorder With Windows XP, My PC Continuously Reboots On Its Own.
    Master:
  • 903 Answers
If after installing your camcorder in XP, the computer is Rebooting on its own, the you must get a Windows update. This is NOT a Samsung Issue. It is a known Microsoft issue with XP. Run a Windows Update and download the update marked: KB822603, USB 1.1 & 2.0 update. This will fix the issue of rebooting. Reinstallation of device drivers may be necessary.
Posted on Sep 07, 2005
Win xp on boot up goes to blue screen quickly then reboots
It sounds like a driver is causing the problem or a new software install, turn the PC on and when you hear the beep press the F8 key, you should get a start menu, select safe mode, if this gets you in use system restore to take it back to a date it worked.
May 14, 2014 | Microsoft Using Windows XP Professional:...
System tries to load windows xp, then just reboots itself continuously. tried different hard drives with the same result
Because if you change the HDD ussualy the windows doesn't automatically works. Loading the drivers and settings for another mainboard will make it CRASH. Put an empty HDD and reinstall WINDOWS. Ask for directions here
Nov 30, 2012 | HP Compaq nc6400 Notebook
Now What can i do to get my Bios to recognize my Hard drive ? I took Drive out Hooked it to USB adapter And i could see files open files ,On reboot USB attempts to boot and i see Windows XP screen but,...
here is a software available to back up and make the hard disk recognised by the mother board.you can still do it by installing a fresh copy of windows xp
Apr 03, 2012 | Gateway Computers & Internet
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything memory intensive it simply flashes a blue screen at me then reboots. Whats more is after it reboots it won't...
Your Operating System (OS) is corrupted.
The best solution to this problem is to reinstall your OS using an OS installation CD.
I would also recomend upgrading to Windows XP.
You can upgrade by simply installing Windows XP on your laptop.
Back up all your data before reinstalling your OS.
Jan 07, 2010 | Compaq Presario 1200XL104 Notebook
I installed xp home and now it just keeps saying it couldnt start up normally....so i select Start windows normally and it reboots with the same message
if it failed to boot normally after installing it then it wasn't installed properly, try re-installing. if still the same problem.. try another installer
Oct 23, 2009 | HP Pavilion 6745C (P1442A) PC Desktop
At start up my computer reboots 2 or 3 times
Hi there!
Try running on safe mode. Here's how you do that power on your PC press F5 continuously untill you see the boot menu and select safe mode. from there run the following: antivirus, checkdisk and spyware removal. hope it helps.
Mar 18, 2009 | Medion M3 Director 5100 PC Desktop
Card seems to be defective - slow, reboots, fails on resolution change
If Windows is continuously loading up to 800x600 then your drivers are not being installed. Are you using the the 169.21 Nvdia Forceware package? What OS?
Jan 09, 2008 | ASUS N6200/TD GeForce 6200 AGP 256MB DDR...
"This Software Has Not Passed Windows Logo Testing"?
Microsoft developed the Windows Logo Testing as a standard for all software to meet before receiving a "seal of approval' from Microsoft. Software must pass a series of tests in order to pass the Logo Test. However, just because a program or software has not met Logo Testing criteria, this is not an implication that the software should not be used or that it is not Windows Compatible. Pass and Fail Each test case has "Pass" and "Fail" conditions. A "Fail" for any one of the test cases for any one of the Logo Program requirements disqualifies the application for the "Designed for Windows XP" Logo. Sample Tests: Application must Support Autorun for CDs and DVD's Application must Install to Program Files by default Application must Support Add or Remove Programs properly Application must Support new visual styles Application must Migrate from Windows 98 to Windows XP Home Edition Application must not require a reboot inappropriately You can still use this software with Windows.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
75 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
