Question about Venturer CD2770 CD Shelf System
Cd door will not open
When I tilted the stereo up a cd slid off the cd tray and got lodged in the back. I was able to retrieve the cd by turning the stereo upside down and tilting it forward but now cd door will not open when eject is pushed. Is there a way to manually open the cd door?
Same thing happened to me. turn the system off, unplug it. then back on and after you switch to CD mode (for some reason the CD tray will not eject unless in CD mode), once the system tries to lock on to a specific CD tray, hold the eject button down for 5 seconds. that worked for me. may have been dumb luck but can't hurt.
Posted on Jan 10, 2009
Door will not open
this product seems to be an audio CD player in use with a stereo system.
Have you tried inserting a paperclip (that has been straightened out) through the tiny hole available to manually coax the tray to come out. It will pop out just a little, but it will then be unlocked and be easy to bring out, displaying the entire CD.
If you have tried that, then.....
Take the cover off (the entire case) and inspect the area where the CD is. Many of these players have no metal encasement around the CD mechanism and one can see the inner workings. The CD may have gotten askew, or the mechanism jammed. Gently try to free things up.You should at least retrieve your CD.
Put the thing back together. Use a junk cd (keep the stereo amp off) and try to load and unload it. If that fails.... Time to get a new one.
Here's a suggestion for that. Most all DVD players handle cd's. Purchasing an inexpensive DVD player might be cheaper than finding a stereo component CD player. Just use the audio out.
Good luck
---Sam
Oct 04, 2012 | NAD C521 CD Player
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Cd does not eject from kenwood kdc-138
First if your still under warranty return for new player if not carefully remove top and bottom covers check for any clear tape holding cd door shut or Look at LED sensors blocked by strofoam or cardboard that may have gotten inside the home position guide (the tray that holds the CD) the LED's are located at the front where the door first opens and at the rear where the CD goes deepest into the player,lightly clean with cotton ball and alcohal first remove hot wire ,Now turn cd player upside down and tilt side to side listen for loose screws or other debree check make sure belts are all tight by lightly tugging with index finger turn gears only one eighth of a turn never force anything, if they move that is a good sign, by moving the gears out of position when it is turned back on it will try to find home position, reconnect hot wire and try CD player again.Do not get grease on LED's make sure there is nothing on the CD like a sticker making the cd to thick will clog the device.if still no joy hand turn the gears until the cd is all the way out.Try different CD again never force good luck
Aug 26, 2012 | Kenwood Kdc-138 Car Cd Deck Auto Stereo In...
I have a burned CD in the CD drawer and I can't retreive it, I can't find the button to open the door. Somewhere there is a button" OPEN DOOR" but I can't locate it.
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem openning with the Eject button, then the CD drive may be faulty and needs replacing.
May 19, 2011 | Gateway Computers & Internet
CD slid off the CD tray for printing and can't retrieve the CD from inside the printer. Should I remove something from the rear of the printer to retrieve the CD? Just bought the printer on October 21,...
Yikes!
You might disconnect the cord and remove the paper and anything loose.. and try to lift the printer up and shake it out (since you can't really reach it). The print cartridges should be locked in place so they shouldn't fall out. The paper tray may rattle around but it should also be secure, even if it slides a bit.
Try to shake it gently to get the CD out.
Barring that effort, you'll probably be best advised to take it to a technician who knows who to get it open properly, and more importantly how to get it back together. 8^)
Jan 04, 2011 | Epson R1900 Printer
Cd player wont eject cd
Try this:
Starighten a paper clip and gently push it into the small hole situated usually just below the tray door until you feel some resistance: continue to push gently and the door should open slightly - enough for you to pull it open and reclaim your disk. Make sure the PC is turned off before you do this. You may then find also that the CD tray will co-operate again when you turn it back on.
Sep 10, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
Can't open CD player
Unplug.
Take top off. (Screws on the left and right sides sides.)
Use latch leaver on left side, near the front to release front door.
Remove all CD's from inside or in the CD tray.
Put lid back on.
Nov 10, 2008 | Technics SL-MC6 CD Player
Cd door won't open
I just bought the same system a week ago and my stereo door is completely broke and the cd peice doesn't eject
Dec 31, 2007 | RCA RS2664 Shelf System
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Venturer CD2770 CD Shelf System Logo
520 people viewed this question
Top Venturer Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
