Question about RCA P52926 52" Rear Projection Television
WEAK POWER LINE
Are these expensive to replace?
  • gmiles83 Sep 02, 2008
    Hey Ronnie Had a guy come out and look at my TV.
    He Stated that since it was a RCA-HDTV model it will be hard to find someone to repair it. Because it is I quess digital?
    What do you think?
Thanks ronnie, I will call around to see if I can get someone to help with my Tv, its a 52 inch Model. Only 7 years old.
Don't want to give up on it now.
Thanks alot
Posted on Sep 02, 2008
    Genius:
  • 2,920 Answers
Power lline or power supply?
  • Ronnie Houston Sep 02, 2008
    i think any shop can repair them if you call around it shouldnt be difficult to find a shop at all. i think maybe it was beyond his expertise.call some shops tell them what make and model you have and they will tell you to either bring it to them or they will come to you to repair the set. dont all one persons judgement cloud yours ronnie
Homelite 7-19 weak spark, will not fire
If it truly a weak spark, you may need to replace the ignition module. They are not very expensive and I didn't find it hard to replace. This is a link to an example, you need to be sure you have the correct one for yours:
https://www.amazon.com/Homelite-Ignition-Module-Adv-Tim-850108002/dp/B000PLYHVW
Dec 02, 2016 | Cars & Trucks
Why do i get a increased battery discharge message on bmw 2012
1. If you have a sound battery (and you may not) most likely the alternator is providing insufficient charge to the electrical system in the vehicle when driving and the demands of the system are drawing power from the battery.
2. The battery itself may also be weak and need to be replaced. A weak battery will frequently generate system warnings of various kinds. If it is the original battery still in the 2012 car then as a first step replace the battery with a new one as they can easily begin to fail at 3 years.
The electrical systems on these cars are extremely complex and if you still get the warning message after the battery is replaced then take it to BMW service and have them check the car over. Yes I know that is expensive but that goes with buying that particular brand of car. When you have problems in future with these cars, and you will, they will inevitably be quite expensive to fix in many cases and require specialist knowledge.
Nov 30, 2015 | 2012 BMW 1 Series M
How do you fix the leak in power stering line
This very much depends on where the leak is coming from. Hoses are generally the weak point. As they get older they can deteriorate and then crack causing a leak. Ageing hoses tend to make the power steering fluid very dark (normally a light honey). There are two cheap temporary fixes to go for. Th first is self amalgamating silicon tape ("Rescue Tape"). Wrap this as tight as you can up and down over the leak in the hose about four layers thick. An alternative is to add 'power steering leak stop' fluid to your steering reservoir tank. You will need to take some fluid out with a turkey baster of if already low due to the leak just top it up. Circulate the fluid by running the engine and turning the steering wheel from lock to lock. The more expensive and long tem solution is to replace the hoses with new ones.
Jun 21, 2014 | 2000 Dodge Durango
Power steering tank wont hold fluid and leaks out beside driver tire
Sounds like a blown power steering line. To confirm, wipe down all surfaces around the power steering unit including the lines. Replace the power steering fluid and start the engine. While 1 person is inside the truck, have them turn the wheel from side to side while another watches the area around the power steering unit paying very close attention around the lines. The high pressure line is the most common cause for leaking fluid. If there's no crack or kink in the line, the issue may be the fitting itself where it connects to the power steering pump. Both parts are pricey but replacing the high pressure line (about $150 at the dealer) is certainly less expensive than replacing the whole power steering unit itself.
Jul 30, 2011 | 2004 Hyundai Santa Fe
Weak power to fuel pump
Please check : 1. wiring of pump ( Are there broken cable, loose connections) 2. Pump and its relay ( Are they in good condition?) Weak power to your pump means high resistance on power line make significant voltage drop that cause lower pump power
Nov 28, 2010 | 1999 Acura 3.5RL
1985 Honda trx 125 no power at coil wires & no spark at plug
Hi, Sounds like you may have a faulty rectifier. Should not be too expensive to replace.
Apr 09, 2010 | 2002 Honda CR 125 R
Power steering pump needs to be replaced -----90K, is this normal
the line replacement would be based on cracks/expense/or difficulty to get at. Sometimes, it is much easier to replace hoses at the same time...
if the hoses are okay and not cracked or damaged, leave them.
Mar 10, 2010 | 2008 Acura Rdx
Window will pop up and say replace weak battery or switch to a/c power. how do i do that?
you must have a battery backup on your system. You battery must be going bad, and windows is saying you need to replace it. Sometimes you can get lucky and get them for cheap and sometimes very expensive.
Nov 20, 2009 | Toshiba Audio Players & Recorders
Loud whining noise sometimes after driving for a
Not really expensive just messy to repair. Return lines (low pressure) are much more common and they travel along the frame rail on the right side of the subframe from the power steering rack to the cooler line in front of the radiator. The high pressure line starts at the pump and travels over the top of the motor to the back side (it's a thick line with a big banjo bolt at the pump). They go too but less frequently.
If it's the return line and not the pressure line you can cut it and put some rubber hose from the parts store over the cut part with a couple clamps and that'll hold you for quite a while till you can get the line and get it installed.
The return line, done correctly, can be a bit of a bear on the ground but it's fairly quick in the air on a lift at a garage. The pressure line isn't too bad and can be undertaken by the home mechanic.
Nov 20, 2009 | 2002 Hyundai Santa Fe
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
