Question about Toshiba Satellite A75-S229 Notebook
Satelittle A75-S229 shut off
My lap top shuts off for no reason all by itself. Not hybernating, not screen saver but shuts totally off. If Itry to turn it back on right away, it shuts off again within a minute. If I wait until it has cooled off, it will run for an hour, maybe two before it goes off again. Is this a common phenominon with this laptop? Is it an easy fix?
  • Toshiba Master
  • 1,606 Answers
The cooling heat sinks in the A series are very tight small and if you have dust, pets, gas heating it will collect enough dust in 3-6 months to cause the over heat problem. A external cooler really doesn't help much as the airflow is either restricted or the surface covered in enough dust it can't wick away the heat.
If you have pets or cook near your laptop or use a perfumes you may have to take it apart to clean it out. Cat hair is bad as it is fine and gets right stuck in there. Hot cooking oil vapour will float around and get sucked in and that gets the dust in the air to stick to it. Perfumes are another type of light oil and have the same effect sooner or later. There are web pages that show how to take apart and reassemble the laptop. The hardest bit is actually separating the case half's.
Before you go to that stage you can try blowing it out with compressed air. Normally you never want to use compressed air near any computer. That stuff makes me money as it forces crud into and under parts (Use a vacuum). You need a couple of toothpicks or something that is non conductive and will fit into the screen and stop the fan from turning. If the air is able to turn the fan you will end up buying a new one as the air spins its way too fast for the bearings. Turn the laptop upside down, insert the toothpicks into all fans, then blow the compressed air in from the exit. You are trying to blow the stuff off and out the way it came not stick it harder in. You will probably see a good puff of dust when you first aim the air into each exit. And you will be surprised just how little dust it takes to overheat these. Put it this way if you ever slapped the dust off of your pants that will be about 10x more than what ti takes to over heat these. Once you have given each exit a good couple squirts of air, take the toothpicks outs, flip it over and turn it on. Now if you feel the exit air it will no longer be hot but just warm even after several hours of hard use. You just saved yourself $50 or more.
Posted on Nov 13, 2008
This is a oh-so-common problem for the Satelite A70/75 and it usually is caused by one of two things. If you google "Toshiba Satelite heatsink overheating" and/or "Toshiba Satelite DC plug" you will get a very extensive list of options to repair the problem.
This should take care of the problem and if it doesn't please let me know - it will mean I have something new to look forward to!
Posted on Sep 04, 2008
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.
Posted on Dec 07, 2008
    Problem Solver:
  • 15 Answers
My dad has a Satellite laptop as well, and they do seem to run fairly hot. I'm not sure if this is your problem, but there are many products available to chill laptops down a bit.
One is the Antec USB-Powered Notebook Cooler
Posted on Aug 27, 2008
4 Suggested Answers
  • 84 Answers
SOURCE: Toshiba A75-S229
Try updating your bios and any associated hardware drivers. Your BIOS can be download from this link
Posted on Jul 06, 2007
  • 1606 Answers
SOURCE: overheating and shutting down within several
The A-70 and A75 series both suffer from a very tight cooling system. If you are running a P4 its pretty marginal. Basically what you need to do is blow out and or clean the cooling system. On my A70 I had to do it every 4-6 months. Basically as soon as it started getting past warm on the bottom of the laptop it was time to blow it out.
Basically what happens is dust and oils (cooking oils, perfume oils etc) and hair collect on the cooler and reduce how effective it can cool.
So what you do to clean it is get a can of compressed air (keyboard blow off stuff) and two toothpick. Take the battery out and unplug it.Turn the laptop upside down. Insert the toothpick in the cooling fans. This is important as the air can turn the fans faster then they are meant to spin and could damage the fan bearings (new fan annoying and expensive -lots of labour). Take the compressed air and blow in from the exits and then blow in over the fans. What will surprise you is just how little dust will come out. It may just be one good puff of dust and thats it. When you do this a couple of times or don't see any more dust you are done. Take out the toothpicks and put the battery back in and turn it on. It should run much cooler.
Posted on May 17, 2010
Testimonial: "I thought the fan was shot... however, blowing out the fan did make a noticeable difference. I also used a ShopVac and vacuumed the back. I ran the laptop for over an hour and it never shut down. Thanks!! Great Advice!!"
  • 2296 Answers
SOURCE: Hi. My notebook (Toshiba Satellite A75-S229) is
To avoid laptop overheating, follow the information from this link.
Posted on Jan 05, 2011
I have a dell inspiron 570 desktop and instead of going to sleep it shuts completely down. I was told it is hybernating so how do I disable the hybernation so all it does is go to sleep until I shut it...
Start>control panel>power > find the settings for sleep/hibernation/screen saver
Also, check all your settings at the screen saver level by right-clicking the desktop. There can be some funky stuff set in here.
Nov 10, 2012 | Dell Inspiron 570 PC Desktop
My computer turns off the power itself. what should i do
Right click on an empty part of your desktop, and choose properties. Click on the Screen Saver tab, and then click on the Power (Settings) button. Here is where you can change how long it will take for your computer to shut itself off.
Mar 05, 2011 | Toshiba Satellite A75-S1253 (PSA70U1YC00E)...
Terminals shutting down after minutes of inactivity goes back to user name screen
check screen saver time, also look at Power on the Screen Saver Tab, it may be set to low time, change it to 20 mins for "TunOff Monitor" and other settings like Hybernate etc
Dec 07, 2009 | LXE VX6 64MB 1 ANT 10 Inch INDR QWR ANSI...
Laptop shuts down
HI- I have one and it shuts down to. For us it was a problem with overheating and dust in the laptop. I beleive there are heat sensors inside the laptop that go, so that could be it. For the most part, when it shuts down, we have found it to be dust as after we clean it, it doesn't happen as much. For the dust- the first time blew air into the fan outlets (both of them) and a ton of dust came out. Sounds simple, but it worked. A tell tale sign may be if your laptop sounds louder than it normally does. We use the compressed air can every so often and even just put the vacum nozle over the fans (you'll hear them whirl and see dust coem out). I also have the lap top sitting on a "vent filter" like people use for thier heting/ac vents (WEB Electrostatic Vent Filters).They come in 4x12 sheets and are cheap. The fans **** up a ton of dust and this helps keep some of it out. Good luck...Steve
Apr 14, 2009 | Toshiba Satellite A75-S229 Notebook
How to remove Toshiba A75-S229 keyboard
Here is the site I use when I get stuck with repairing Toshibas Good Luck.
Dec 22, 2008 | Toshiba Satellite A75-S229 Notebook
Toshiba A75-S229
Jul 06, 2007 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite A75-S229 Notebook Logo
297 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
