Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
I need to set the camcorder to default settings
How Do I Reset The Camcorder Settings Back To Factory Default?
    Master:
  • 903 Answers
For most models, removing the battery pack from the camcorder will restore the default settings; however, some models which contain an EZ Q button, store your settings and removing the battery pack will have no impact on these settings. The Lithium battery maintains the clock function and preset contents of the memory; even if the Battery pack or AC Power adapter is removed. Removing the Lithium Battery along with the Battery pack will restore the default settings.
Posted on Sep 07, 2005
SOURCE:
Where is the reset button on the mv650i?
There isn't a "manual" reset button on the camera. You access the rest to factory default settings in the menu options.
Jul 18, 2014 | Canon MV650i Mini DV Digital Camcorder
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Jun 26, 2011 | Computers & Internet
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
My clients are complaining about the darkness of my movies taken with this DCR-H30 camcorder.how can I adjust the settings of the camcorder for perfect results
the camcorder is suppose to give you good result even on its default settings. try to reset it first by pressing and holding the reset button.(reset button is located in the panel where the lcd screen comes from. its a tiny hole and you can use any pointed object to press and hold it for 3 seconds. try recording again. if you're having a hard time looking for the reset button, try removing ll power source from the camcorder(battery and unplug it from walloutlet) then press and hold power button for 1 min.
Sep 07, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Jul 08, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
JVC Enverio GZ-MG155 30gb camcorder
Try removing the battery and see if it changes back to the default settings.
Aug 04, 2008 | JVC Everio GZ-MG130 Camcorder
SC-D363
hmmm, the only thing i can think of is to try the easy Q mode and see if it works ok , when it is in easy Q mode it puts the video camera at a default setting and you cant change any of the menu options until you take it out of easy Q.
hope this helps
May 16, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Is there an easy way to reset all settings on camera back to factory default
Here is the link to the user manual for your camcorder if you need it; http://books.jvcservice.com/download/685826248/21964.pdf There does not appear to be a factory settings reset, however in the manual, all the settings and their preset values are listed. You could try removing all multimedia cards, battery, power supply and leaving the unit for around 3 months! (page 11) to discharge the internal memory cell, or if you feel competent to take the camcorder apart, you MAY be able to remove and replace this battery. Unfortunately I think the resets have to all be done individually, or take the camcorder to a service centre to see if they can discharge the internal memory cell - this is probably not a good idea, dependent on the exact tyoe of cell used. Hope this helps some :)
Mar 31, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
636 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
