Question about Canon imageRUNNER 400S Copier
Error code i heve a system error E001 on my ir 2016j copier
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Temperature too high
change the thermistor in the fuser unit
Posted on Aug 27, 2008
How to solve the error code E00001-0010 canon iR-ADV 6255i
Fuser noise and intermittent E001 code error :
The upper fuser roller section makes a noise and intermittently error code E001 occurs.
Nov 03, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
How do i fix Error E007 on Canon IR 2016j?
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
Canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon imageRUNNER 400S Copier Logo
120 people viewed this question
old marine
old marine
