Mr.Shah,
I have geovision 800. show vieo lost on all cameras. I have checked all connection, they seem to be fine. I have replaced the power supply box. i have uninsatlled driver and software and reinstalled. nothing seems to help. and system makes constant beeping noise.
what wuold you suggest I need to do?
-   I am currently at a clients house trying to resolve the non-stop beeping on Win XP PRO. I suspect GeoVision is causing the beeping becuase it only appears to make this noise when GV is open. I am removing GV, and will reinstall. -   Guest
Jan 24, 2009
-   I have the same problem. Running version 8.0.1.-   ccurry12
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
I'm losing video and all the cams are in the same row. GV-800 it is a new system and the cams were...
(More)
I'm losing video and all the cams are in the same row. GV-800 it is a new system and the cams were already in place from another system and working fine. the cameras also are recording when nothing is there(motion sensing) 1 camera has lost its real time video, it will show but it skips while the others show in real time.
I have Geo Vision GV800 with 9 cameras running, i try to add more but cannot figure out how to get...
(More)
I have Geo Vision GV800 with 9 cameras running, i try to add more but cannot figure out how to get them to show up on my monitor when i click anything past nine it does not show
Hi we are using a GV800 card and GV software version 8.3 Recently we have replaced the exisitng...
(More)
Hi we are using a GV800 card and GV software version 8.3 Recently we have replaced the exisitng cameras and also connection wirings. Now we are able to see the video but we are unable to hear any sound. When we check this under audio setup a very loud noise sound is received instead of actual voice. The cameras we use have a direct port for power supply, one seperate port for video and one seperate port for audio. it seems there is ome problem with the wires/sockets. Please advice how can we correct the wiring
I have a GV800 with 16 inputs, and I want to add 2 more cameras, there is a option on the menu for...
(More)
I have a GV800 with 16 inputs, and I want to add 2 more cameras, there is a option on the menu for adding cameras but it onli gives me the option on the original 11
