Question about Brother HL-2040 Laser Printer
All LEDs are flashing
The Toner, Drum & Paper and Ready lights are flashing. I have turn the power swith off and then on, waited the 10 minutes and it still wont work
Please resolve.
  • inpobon Sep 06, 2008
    Brother hl-2070
    I have the same problem with my copier, all led's are flashing after swichting on!
    Switching on and off no result.
    inpobon@telbonet.com
  • 3 Answers
If you hold the two buttons down, this will give you a secondary error code which will tell you the exact error. All lights flashing is a service error.
Posted on Sep 10, 2008
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Apr 09, 2014 | Dell 1720dn Laser Printer
I have a Brother HL - 2040 printer. It has been turned off. Having switched it back on I now have the Toner, drum and paper lamps on and it hasn't warmed up. Does this mean I need to purchase a new...
If all the LED's are flashing and continue to flash for more than 10 minutes with the unit powered up, it needs to be serviced or replaced. (That is toner, drum, paper and the Ready light all blinking -> critical error found in self-test.) If the Ready light is off and the rest of the lights are steady, the toner is out, the corona wire needs cleaning and the paper tray either is empty or not picking up the paper.
See http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11 for details on the errors and solutions.
I hope this helps.
Jan 27, 2011 | Brother HL-2040 Laser Printer
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
1720 Dell Laser printer Photoconductor Problem
I finally figured it out (with Dell Tech Support's help)! When you replace the drum, you MUST reset the counter as well. All you have to do is:
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds
GOOD LUCK, EVERYONE!!!
Mar 12, 2009 | Dell 1700n Laser Printer
First Page printing Jibberish with the Zen thing at the end.
Try these.
Reset the Photoconductor Drum Counter
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
5. Wait till the printer completes the POST process.
6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
Now only the
8. Cycle the power of the printer.
- Remove the power cable
Feb 24, 2009 | Dell 1720dn Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Won't print
This indicates that the fuser req' replacement but it can also be
a mpcb fault.
If the problem occured during a flash storm i would go for the
mpcb.
mongrelken.
May 21, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
303 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
