Bsod 0xdeaddead. restart and when it wants to.
  • Roberta Smith
    Roberta Smith May 11, 2010
    have you recently added a program or done updates thru microsoft ?
No programs added. Microsoft updates can crash to BSOD 0xdeaddead 0x00000000 0x00000000 0x00000000 0x00000000. When I restart it gos to bsod above. Will be working on a file and it will crash to the bsod above. Not every Microsoft update will crash in the process of installing but some have. No new hardware or software has been added for sometime now. Streets and Trips has been loaded and taken off several times because it will not run with out a startup error. Everything other than that works fine.
Posted on Aug 27, 2008
BSOD AFTER CLEAN INSTALL 2X
Since you are getting the same result from the same actions I would say that you should change the hard drive. It may be defective.
Mar 16, 2014 | Gateway NV79C48u Laptop
How do i repair a blue screen of death
restart your system manually. If BSoD appears on every restart, then try to remove theproblem which it is referring to. Try using Windows Recovery cd. Once the Windows boots, go to System Restore in Control Panel and roll back to the most recent restore point.
Or else re-install Windows and check.
Normally BSoD appears if there is a critical hardware/memory error.
Sep 19, 2010 | Computers & Internet
Continouse restarting
This is usually caused by a BSOD error. If you boot with F8 (hit it several times a second once the computer is powered on), one of the choices is to boot without automatic restart on errors. This will reveal the BSOD which you might be able to fix.
Post back what it says for further help.
Sep 09, 2010 | Computers & Internet
My pc would start up, then flash this blue screen for a milisecond, then start up again
Log into Windows Safe Mode (F8) and turn it off Auto Restart by doing the following:
  • Right Click on “My Computer”
  • “Properties”
  • “Advanced” tab
  • and under the headline “Startup and Recovery”,
  • “Settings”
  • uncheck “Automatically Restart” box
  • press Ok.
Now the BSOD will not disappear and you can begin to fix the problem. To solve a BSOD problem go here:
http://tinyurl.com/29vpw4j
Aug 17, 2010 | Compaq Evo D500 PC Desktop
My PC boots up and then restarts. There is no set pattern to this however. It may be on for 2 minutes or 8 hours before it does this.I've tested the power supply, it's fine. Any advice?
One of the programs set to be loaded at boot fails, you get a BSOD and the pc restarts. You need to find what the BSOD says to stop all of that.
To see the BSOD you need to stop the pc auto-restarting:   Start / Control Panel / System  /Advanced / Startup and Recovery / Settings... > under System Failure un-check "Automatically restart"
May 26, 2010 | Computers & Internet
After installing memory update (from 512 Mb to 1 Gb) computer restarts as soon as Windows XP kicks in
The system restarts because of BSOD, blue screen of death. .The system gets the BSOD and automatically restarts..
This is an issue with the RAM CHIP, the CHIP has errors, try changing the RAM with the same shop you bought, if you had bought it as new else change using warranty...
Please rate this solution
Rnj VINODKUMAR
Oct 20, 2009 | ASUS Computers & Internet
Every time i try to turn on my computer it shows bsod for a split sec and the restarts again? can u help?
You can configure Windows to not automatically restart when a bsod occurs. In the Control Panel, go to System and then select the Advanced tab. Then click Settings under Startup and Recovery. Clear the Automatically restart checkbox.
Now when the bsod happens, it will stay until you power down the computer. You can read the STOP error of the bsod and any potential file name. Now you can search for the exact error and solution.
This article on troubleshooting blue screen errors might help you further.
Jul 29, 2009 | Computers & Internet
Disply Problem
its a driver problem, my bud had the same probs with a older nVidia but gives same BSOD msg. just up date the drivers or reinstall them. http://www.nvidia.com/object/winxp_186.08_beta.html all picked out for ya just C&P it. oh and after downloading new drivers uninstall the old drivers in the add/remove, restart and turn off the found new hardware wiz then install new drivers and restart again. sad to say that the BSOD was only hapaning cuz my buds card was dieing. hope that yours lives =D
Jun 09, 2009 | XFX GeForce 6200 Graphic Card
Computers & Internet Logo
355 people viewed this question
David Payne
David Payne
