Question about GE Microwave Ovens
Microwave went crazy and shut down, decided to replace but before i did i replugged it in and now it works. did it reset itself or is it temporary? model g.e. 1540 9 yrs old
  • GE Master
  • 9,086 Answers
It could have been a glitch caused by a line surge, which you cleared by resetting it by unplugging it. That's not uncommon.
It may have a bad connection or a bad magnetron causing interference.
As long as it's working okay, I would keep it in service.
Posted on Sep 01, 2008
Siemens Innowave 'n890l6u5 rsgs'
sadly you destroyed the unit only option is replacement of same
Aug 11, 2017 | Siemens Microwave Ovens
The microwave shut off by itself. Is there an auto shut off? I ask because I was reheating some squash and the microwave shut off. No lights nothing. Sugestions?
Check it after 2 hrs .By repluging it.
If you use microwave alot then it might get too hot,So just try it.
Otherwise give some more detail to me to trouble shoot it.
Thanks
Sep 11, 2011 | Jenn-Air Microwave Ovens
GE Spacemaker XL 1800 Microwave. After removing heated food, I closed the door and the microwave sounded like it was powering up again. However, no internal light came on as it does when the unit is...
Be sure to keep this oven unplugged or the door open until it is fixed. If it runs by itself, this is a fire hazard.
First listen carefully for a buzzing sound behind the control panel when the door is shut.
If it's present, chances are you have a failing capacitor on the control panel assembly, which can be repaired for $39.95 in most cases. Details are here.
If that or a louder buzzing is only present when you have the door closed, then the oven is cooking when it's not supposed to, but the cooling fan is not on, and it is overheating and tripping the breaker.
That would be due to a shorted cook relay on the control board. That can also be repaired with our $39.95 service.
The odd characters on the display concern me separately. This could mean you have a noisy or otherwise failing magnetron.
If the display is fine when you're cooking properly with it, then the magnetron is probably okay.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 28, 2011 | Microwave Ovens
Sunbeam microwave model SGB8901 will not stop running.....
I had the same problem, but didn't have the box anymore. The store let me exchange it for another one but that one is doing the same thing too.
May 24, 2010 | Microwave Ovens
My microwave overheats after about a minute of use. It shuts off and takes about 5 mins to reset. Is there a simple fix for this without replacing the unit?
The most likely cause of overheating is the magnetron tube, which generates the microwaves. As it ages (or simply due to early failure) its power falls, it works harder and gets too hot, and a safety thermostat attached to it shuts the oven down. Then, as you've noticed, the oven comes back on when the thermostat resets.
It's possible the thermostat itself is bad and opening too early, but this is seldom the case. The magnetron can be replaced, but it's generally not worth the cost of repair. It's an expensive part, and with labor charges you'll spend close to what a new oven costs. (This is why I'm not in the service business any more. Can't make money fixing cheap appliances!)
If you want to keep this oven, take it to a shop for a diagnosis and estimate. Then let price be your guide. I don't recommend trying to fix this yourself. Even though it's not a difficult repair, there are lethal voltages under the cover and microwave leakage can result from improper repair. Leave the service to professionals.
Hope this helps you decide what to do. Thanks for using Fixya!
Feb 12, 2010 | Magic Chef MCD1311ST Microwave Oven
Emerson Microwave
Did you unplug it for several minutes and them plug it back in?
If that dosn't resolve your problem, it sounds to me like the microprocessor controller board has failed and will need to be replaced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 13, 2008 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
