Question about Home
Power showers I have a power shower that has stopped working. First it came on then had an interupted water flow and would come on again. Now it just doesn't work. Will I need a new one or could it be something simple. Regards Paula
  • 55 Answers
Try removing shower head-look for debris. I seems you might have lost water flow.
Posted on Aug 27, 2008
Water stops flowing
It sounds like the plumbing system has some type of device to prevent someone from using the hot water from a common water heater too fast for the water heater to keep up the temperature.
Aug 31, 2014 | Home
When the shower head is in the holding pole it does not work. But if we take the shower head out and hold it down low, it works okay. Any idea what theproblem could be?
you do not have the water presher for the shower head at that the height you have it you may have to get a water pump from b&q or ebay
Aug 10, 2014 | Home
Selectronic redring shower powering up , no water coming out and then turns off after approx 10 seconds
There are some troubleshooting actions mentioned on page 6 and 7 of the manual at this site
http://www.aroundtownflats.com/manuals/Shower%20Manuals/Redring/New%20Selectronic%20Instructions.pdf
The shower is designed to turn off within 30 secs if there is no water flowing through. The issue is why does water flow stop.
It can happen if shower is in overheat shutdown. Need to find if temperature setting is too high. There is a purge sequence to overcome this. See manual.
Apr 21, 2014 | Home
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
No running water from my shower
Check water lines to shower and make sure that there is no blockage or water cut off to it. Valve itself could be bad also or blockage inside it.
I f it is a tub & shower unit the diverter may be bad or stuck in place restricting water flow. Some are push button on the valve or a pull unit on tub spout to send water to shower head.
Cut water off and remove to inspect for reason not functioning correctly.
Remove shower head to inspect for blockage. The srceen may be stopped up for the shower head. Remove turn water on and see if any flow comes out shower arm.
May 19, 2010 | Home
Water flow stops and starts
check PRV...Pressure reducing valve......Plugged ro broken.....
Apr 22, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Home Logo
314 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
