Question about Rainbow E series Canister Wet/Dry Vacuum
Changing the two HEPA filters in the Rainbow E Series.
I changed the one filter located on the blow side of the canister. It is a little different than the one I removed. It has a black plastic thing that is in the middle so that when I put it back together it looks like a protective shield on the filter. Is it installed backwards? Also, how do I get to the internal filter to change it? Thank you for your consideration.
  • Tim Babcock
    Tim Babcock May 11, 2010
  • Tim Babcock
    I have to date myself here but when I was involved with Rainbows we didn't hepa filters on them at the time. I'm going throw this to the experts and see what kind of answer I get.
    I should have an answer for you in a few hours.
    Sorry about that,
  • Rainbow Expert
  • 324 Answers
Plastic thing is fine. it probably has "e" in the middle...
To replace the motor filter you would have to remove cap. You have to get clear plastic lenses off the unit (you will need small flat screwdriver to release latches on the top of the lenses). Under those you will find a total of 4 or 6 screws. They hold the cap onto the main body. Filter is under the cap. See HERE if you need the filter.
Good Luck
Posted on Dec 06, 2008
Rainbow filter spraying water just changed filter?
If your Separator is broken, then this will allow water to go up through the motor and out the exhaust. The HEPA Filter Neutralizer 2nd Edition for eSERIES is at the end of the air bath of exhaust so this will be soaked with water. If that does not fix, call us with your Rainbow in front of you for some troubleshooting... Contact Us
Aug 06, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Where is the best place to buy a hepa filter for e2series type 12?
You can call me and I will be happy to mail you one. I am an authorized service center. Doris 979-966-8186
Jul 06, 2014 | Rainbow E series Canister Wet/Dry Vacuum
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
If you dopn't change the hepa filter will motor burn up or explode
No. The HEPA filter is simply to collect fine dust and allergens that make it past the water. Hmm. If it gets full/clogged and isn't changed, then the motor is more likely to burn up from overheating. It's more likely it will shut off if the filter gets full. It will not explode.
Dec 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum loss of suction
If it is not the Hepa filter, you can check it by removing it running machine and seeing if there is a difference. It is always good to have your unit serviced about every 5 - 8 years or so.
Mar 29, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How do I change the hepafilter on my Rainbow E series? Thanks
You have to remove rear cover (on the opposite side than the intake is) There are 2 kinds of HEPA and 2 kinds of filter covers:
HEPA encased in black plastic - on the bottom of the unit you will see two latches and you can use a flat screw driver release them and filter cover just pops out.
HEPA older style (white filter with black plastic frame) - there are 2 Phillips screws on the bottom of the unit and 2 more under the cord caddy. Use flat screw driver to remove the cord caddy (put it in between the housing and the caddy and it would come off)
If you need filters - they are HERE.
Good Luck
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Changing the filter in Rainbow e series
Some of the e-series has a corrugated filter in the top section. To get to it, remove the clear plastic panels that are the sides. Most have 3 screws on each side to move, then the top half will come loose. There also is filter on the back, there is a door to remove to get to it.
Jun 03, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
330 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
