SERVICE MODE PANASONIC TV 54CM, MODEL FX 54 HOW TO ENTER SERVICE MODE (FACTORY SETTINGS) I WANT TO ADJUST FIELDS, (VERTICAL SIZE)
  • del504 Mar 05, 2009
3 Suggested Answers
  • 197 Answers
SOURCE: I need a code to enter to service mode in
http://www.riddledtv.com/forums/panasonic-service-menu-codes-plasma-lcd-crt-rptv-t287.html
try the above link
Posted on Oct 01, 2009
  • 26 Answers
SOURCE: TV PANASONIC-SERVICE MENU
press "MUTE" on remote control and "V" on TV set, when the sharpness is set on minimum and programme position is on 99.
5. Horizontal Shift H-CTR 31 Optimum setting. 6. Horizontal parallelogram H-PAR 034 {034} [-] Optimum setting. 7. Horizontal bow H-BOW 031 {031} [-] Optimum setting.
Posted on Oct 19, 2010
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2016 | Zenith SY2765S TV
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
How to adjust vertical height for panasonic crt tv model number TC-2119R
To adjust height and other parameters, you have to enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 03, 2015 | Panasonic Televison & Video
How to go to service mode in ct-g2978b Panasonic tv
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 08, 2015 | Panasonic Televison & Video
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 27, 2014 | Zenith Televison & Video
Why the word FACTORY displayed in panasonic tv
It means that the set have been entered to factory adjustment by any way. Improper pushes to remote controls at a definite time, will make it to factory set window. That is, now your set is in service mode option.
To make it out of service mode, and to display the normal user window, you have to exit this mode. Here you haven't provided the exact model number to your TV, otherwise, can provide a solutionl If you wish to get more details about how to enter and to exit service modes, http://electronicshelponline.blogspot.com/ check this link, and pull up older posts there. Service modes to many brand TVs are given in detail. Here you only have to exit this mode. No need to enter it. It has already been done, and TV is in this mode now. Do not make any unnecessary adjustments to data values you see in these windows. It might make the set irresponsible to any commands, either by its front panel controls, or remote control. Check the site patiently. Find out the way to exit it. OK? If you wish to get more assistance, please come by comment by this answer window.
May 30, 2013 | Televison & Video
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
The modes are:
etc.
clock.
service menu.
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
