Yes it is normal for the electric fan to run on a hot engine on a hot day after its been turned off, BUT and this is a big but,it sounds as if your Jeep is not cooling well. Make sure you have clean fins on the radiator/condenser unit in the front. Flush and refill the radiator, and consider changing the thermostat and going to a high flow thermostat/gooseneck cover,did on mine and it helped immensely,they can be found with a simple search on google shopping. Also a good idea to replace your clutch fan unit on your one driven off the motor if it doesn't seem to be cooling well.
You can get more info here:
http://www.jeepforum.com/forum/f11/need-help-98-xj-overheating-1113355/
No it is not normal....have a repair shop check the coolant fan sending unit or the coolant fan relay...a bad sending unit maybe sending a false overheating signal to the fan causeing it to stay on or the on off fan relay maybe sticking on..an make sure the jeep is not actually running hot the temp guage maybe reading the wrong temp
