Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side -freezer issue
Inside at ice dispenser/water dispenser area, icy frost accumulates. Seems that the ice dispenser 'door' doesn't seal any longer. can that be adjusted/replaced with ease?
  • 639 Answers
Friend,
ngfam1 At your service!
That is the problem and it needs to be replaced . But some times service will find more than one part worn and needing replacement!
You need service this time !
Sounds like a Thermostat problem!
If this is 10 years old or more you may not be advisable to put ALOT of good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
My ice maker is making snow in the dispenser area---What can I do to resolve this?
I would look at the dispenser door to be the issue not the ice maker. This door if not closed will allow warm air to enter the freezer and create frost.
You would look into the dispenser door and clear the ice out, use a flashlight, open and close the dispenser door, if you see light after this. replace the dispenser door and or bar, spring, or other related part to the dispenser.
Good Luck
Oct 12, 2011 | Kenmore Side by Side Refrigerator
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Heavy frost accumulates just inside freezer door (and on adjacent foods) -- next to refrigerator door
Check your freezer door seal especially where the frost is the heaviest. Also check and make sure that you ice shoot for the thru the door ice is closing.
Jun 24, 2011 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
3 1/2 year old whirlpool side by side has frost and ice building up inside the freezer compartment close to the door. Freezer seems to run continuously also...help?
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck
  6. 911servicetoday.com
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
Icejams in the drop area.
Ice dispenser will not dispense cubes or crushed ice. Help?
Sep 17, 2008 | Kenmore 53642 / 53644 Side by Side...
Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Oct 18, 2007 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
54 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
