Washing Machines Logo
Posted on Jul 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F35 error need to replace analog switch - Washing Machines
ZJ Limited
Level 3:
  • Master 17,989 Answers
  • Posted on Jul 15, 2011
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14453299
Points
60858
F35 error code means a problem with the ANALOG PRESSURE SENSOR switch operation
Could be a blockage in the air dome or pressure switch hose (Item 29). The pressure switch is located underneath the main top on the right hand side. (See image) The air dome is located on the back of the tub on the left hand side.
If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (Item # 20) Part # W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Part Number W10156252 (AP4323930) is used with the following appliance models: WFW9600TA00, WFW9600TB00, WFW9600TC00, WFW9600TU00, WFW9600TW00, WFW9600TZ00, and more.
Hope this helps.
1helpful
What does error F35 mean?
It helps to have FULL make and model in such questions, but here are a few ideas
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
Jun 4, 2011
F35 error code appears during cycle - iFixit
https://www.ifixit.com > Answers > View > F35+error+co...
About
Whirlpool duet washer f35 error code
https://all-errors.com > whirlpool-duet-washer-f35-error
The F35 error code in the Whirlpool washer indicates some problems with the water level pressure switch. This sensor is responsible for measuring the amount ...
Troubleshooting the F35 Sud Error Code in the Whirlpool Duet ...
https://www.youtube.com > watch
PREVIEW
12:49 Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam Washer · For more tech advice on ...
YouTube · SamuraiRepairman · Oct 5, 2013
2answers
Whirlpool duet steam WFW9600TW00 code F35
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
5helpful
2answers
What is an F35 code?
The F35 error code is indicating the analog pressure sensor switch is either bad or blocked. Go to managemylife.com and put in F35 error code to see location and description of part.
8helpful
2answers
Suds then f35 Whirlpool Duet 4.0 Cu. Ft. 14-Cycle Steam Washer - White
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
2answers
Code f35 and sud on washer machine/whirlpool duet front loader
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
1helpful
2answers
Error code washing is delayed wil wash half the clothes
9helpful
2answers
Model: wfw9500tw01 f35 error
1helpful
3answers
F35 on whirlpool duet ht, tech came out and reset board a few days back...same problem again this morn....talking about a switch. Can you Help
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
1helpful
2answers
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
2helpful
5answers
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Top Washing Machines Experts
john h
