Sony kde-p37xs1 model this tv has two faults one being no sound and the other being vertical lines have appeared on the right hand side of the screen from top to bottom. kind regard dan
5 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: convergence
you need to check your + and - 15 volt lines, sounds like you have bad convergence IC`s and at least one open or way up in value resistor in the convergence section.
Posted on Nov 27, 2007
  • 579 Answers
SOURCE: JVC AV-48WP30 has vertical lines every inch or so...
This may not be the problem but its worth a try:
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
SOURCE: JVC AV-48WP30 started displaying vertical lines every inch
it looks like theres a wave in the top of my screen on my jvc av-48wp30 not sure but i think it has something to do with the bulbs because the projection mirror wasfine and all wires seemed to be hooked up properly.. can you help? tell me where i can find the bulbs to replace them?
Posted on Oct 14, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
  • 22 Answers
SOURCE: 2 vertical bars on right half-side of screen
you are in luck my friend!  i just performed a fix on a gateway plasma that has LG boards inside.  It is exactly what you are talking about.  Go to the attached link and follow the thread carefully and read it all before starting.  IT WILL WORK!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Posted on Apr 28, 2009
Estimated cost for fixing Tobshiba LEDTV? Model#50L3400U. Colorful vertical lines, left hand side but more towards the middle. Lines appear on all imputs and are constant.Lines appear over the menu.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 19, 2016 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
My Sony Tv model EX31 shows vertical line ( white and black) on left and right side. 32 inch. How to solve the problem.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 21, 2016 | Sony Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Sony tv KDL-40S4100 vertical lines on right side
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Bravia KDL46w5500. Why does it display vertical lines all over the screen?
Sep 30, 2015 | Sony Televison & Video
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
Jan 18, 2015 | HCDZ General Remote Control Fit For Sony...
Sony Plasma KDE 42xs955 has delay in of 5 to 10 minutes for picture to appear. Sound turns on immediately
Contact the authorized service centre for Sony. This is not a fault that a normal user can do anything. Electro help
Oct 22, 2014 | Sony KDE-42XS955 42 in. Plasma HDTV
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Repairing a ribbon for X Y board Plasma TV
REPLACED PDP PANEL
Manufacturer Sony Part Number 9-885-081-88 Description PANEL (NP50C4MF01FA
Oct 04, 2009 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
