Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Diagnostic codes for ksc25inss00
How do you input to get a code
2007 Buick Rendezvous park aid does not work. How to fix it?
The ultrasonic rear parking assist (URPA)
The URPA is equipped with a switch located above the driver information center (DIC) that can be used to disable the system.Do you have it disabled ?
Diagnostic Trouble Code (DTC) Displaying
This vehicle is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes using the 3 indicators on the rear parking assist display. After the bulb check has been completed, the red outside indicator flashes to indicate a malfunction with the system. The module disables operation of the URPA system under this condition.
In order to enter the diagnostic mode, complete the following actions:
With the ignition turned OFF, short the rear parking assist diagnostic connector to ground while the vehicle is in PARK. For the location of the rear parking assist (RPA) diagnostic connector, refer to Object Detection Component Views . It's under the front of the center console , by the BCM - body control module.
Turn ON the ignition.
Place foot on the brake.
Shift the vehicle into REVERSE within 5 seconds.
If the vehicle is not shifted into reverse within 5 seconds after turning the ignition ON, the diagnostic mode will still be initiated. However, a reverse input wiring fault will be registered as sequence #7 as shown in the Diagnostic Indicator table below. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes. After the reverse input wiring code is cleared, repeat the diagnostic trouble code displaying steps in order to enter the diagnostic mode.
When the diagnostic mode is first entered, the rear parking assist display displays the amber outside indicator and the red outside indicator. Then, the indicators on the rear parking assist display will display one or more of the sequences in the table below to indicate where the fault exists within the rear parking assist system. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes.
Diagnostic Indicators #
State/Fault Location
Amber Outside
Amber Middle
Red Outside
Flashing
Start of Diagnostics
X
X
RR Corner Object Sensor and Wiring
X
RR Middle Object Sensor and Wiring
X
X
LR Middle Object Sensor and Wiring
X
X
5
LR Corner Object Sensor and Wiring
X
6
Chime Warning Wiring
X
7
Reverse Input Wiring
X
X
8
Important: This diagnostic pattern sets for an open sensor supply voltage circuit and sensor low reference circuit.
Sensor Supply Voltage Circuit and Sensor Low Reference Circuit
X
X
X
X
Flashes in the following sequence:
Amber Outside
Amber Outside and Amber Middle
Amber Middle and Red Outside
Red Outside
9
Important: This diagnostic pattern sets for a short to ground in the sensor supply voltage circuit.
X
X
X
Feb 01, 2018 | Buick Cars & Trucks
We, 07 rendezvous park aid quit working. Needfixed
Rear Parking Assist Inoperative - Red Indicator Flashes
Does the red indicator flash ?
Diagnostic Aids
• The RPA system is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes from the RPA display. Before using this diagnostics, it is necessary to get familiar and understand how the on-board diagnostic feature operates. Refer to Diagnostic Trouble Code (DTC) Displaying and to Diagnostic Trouble Code (DTC) Clearing on how the diagnostic trouble codes are displayed and cleared from the RPA display system.
• Make sure the rear park assist (RPA) object sensors located on the vehicle rear bumper are clean and clear. Remove any objects that is blocking the sensors.
• Inspect for after market devices which could affect the operation of the RPA system.
The Rear Parking Assist (RPA) Diagnostic Connector (UD7) is under the front of the center console behind the BCM - body control module.
Nov 18, 2017 | Cars & Trucks
Why washer will not do diagnostic test or erase E38 error code
[PDF]Fault Code Bible v1.2 - ResearchGate
www.researchgate.net/publictopics.PublicPostFileLoader.html... ResearchGatesimple, clear instructions on how to read the faults or use the diagnostic routines. .....Resetting the error indication does not rectify the fault but only erases from .... E53 Input circuit EMC errors Displayed as error code, washing machine start ... if you choose position 10, 11 or 12, the test will terminate without pressing.
Sep 16, 2015 | Washing Machines
Do I need to input code after chenge new toner?
http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/MFPsPrinters/Manuals/cop_man_ar235_75.pdf Go to page 82 for instructions, no code is needed to be inputted after changing toner.
May 13, 2014 | Sharp AR-275 Copier
Crank sensor code
actually the P320 means Ignition/Distributor Engine Speed Input Circuit
_____________
carprog, a strong car and truck diagnostic tool.
Mar 06, 2013 | 2005 Kia Optima
Diagnostic code for a bad input sensor
Use Google Chrome to ask the question &
find all sorts of stuff
Jan 25, 2013 | Cars & Trucks
Intrepid Issues
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 13, 2012 | 2004 Dodge Intrepid
Code p1445
P1445: CHECK PF SENSOR HIGH VOLTAGE TO PCM
Continuous Memory Diagnostic Trouble Code (DTC) P1445 indicates that Self-Test has detected a PF sensor circuit input above the maximum.
Possible causes:
PF shorted to VPWR.
PF open circuit.
PWR GND open circuit.
Damaged purge flow (PF) sensor.
Damaged PCM.
Jul 24, 2011 | 1996 Mercury Cougar XR7
Check engine light with following codes p 1529 p0720 p0715
P1529 indicates that your TCM asked the ECM to turn on the check engine lamp.
The range switch and the output speed sensors are the items that are abnormally affecting the operation of the transmission. The diagnostic logic in your computer can distinguish these issues from one another, so you'll definitely want to do both. You have no diagnostic code for the input speed sensor (P0715) listed, so I have made no recommendation to replace it. In my opinion, it's not a labor-intensive repair, so I wouldn't recommend replacing it unless you have reason to believe it's bad.
DTC - P0720 (OUTPUT SHAFT SPEED SENSOR SYSTEM)
Code No. P0720 Output shaft speed sensor system
If the output from the output shaft speed sensor is continuously 50% lower than the vehicle speed for 1 second or more while driving in 3rd or 4th gear at a speed of 30 km/h or more, it is judged to be an open circuit or short-circuit in the output shaft speed sensor and diagnostic trouble code No. P0720 is output. If diagnostic trouble code No. P0720 is output four times, the transmission is locked into 3rd gear or 2rid gear as a fail-safe measure.
Probable cause
Malfunction of the output shaft speed sensor
Malfunction of the transfer drive gear or driven gear
Malfunction of connector
Malfunction of the TCM
DTC - P0715 (INPUT SHAFT SPEED SENSOR SYSTEM)
Code No. P0715 input shaft speed sensor system
If no output pulse is detected from the input shaft speed sensor for 1 second or more while driving in 3rd or 4th gear at a speed of 30 km/h (19 mph) or more, it is judged to be an open circuit or short-circuit in the input shaft speed sensor and diagnostic trouble code No. P0715 is output. If diagnostic trouble code P0715 is output four times, the transaxle is locked into 3rd gear or 2nd gear as a fail-safe measure.
Probable cause
Malfunction of the input shaft speed sensor
Malfunction of the underdrive clutch retainer
Is needed replace.
Nov 04, 2009 | 2001 Hyundai Elantra
Self diagnostic test codes
anytime you do the self-diagnostic you will almost always get those 2 codes.
12 - direct power input to the PCM has been disconnected within the last 50 key-on cycles
55 - End of error messages
Dec 27, 2008 | 1997 Mitsubishi Eclipse
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
350 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
