Question about Samsung U900 Soul Cellular Phone
Message tones and vibrate facillity
Does anyone know how to change the message alert tone on the samsung u900 and change the vibrate function.
  • Anonymous Mar 19, 2009
    Thank you so much, i have been trying to figure out for months how to change the message tone. Lol :)
  • 46 Answers
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Posted on Aug 27, 2008
  • Sreenath S Kumar Aug 27, 2008
    Changing the message alert tone
    1. Follow the above procedure until you get to the profile settings you require (points 1 - 5) (in our example, Normal) (Figure 5).
    2. Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display). A set of message alert settings appears (Figure 13). You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
    3. To change the Message alert tone, press the Message alert tone panel (Figure 14). In the menu that appears, press Change. Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) (Figure 15). In this example, press Use my alert tone.
    4. Press the Sounds option (Figure 16). In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files,Ringtones that are loaded onto the phone, or My voice clips (Figure 17). In our example, we'll again choose a file from our Music folder.
    5. Press the Music option. A list of suitable MP3 tracks appears (Figure 18). Tap the one you want in order to highlight it.
    6. Press Options, then tap on the Select menu option to install it as your message alert (Figure 19).
    7. You are now taken back to the Normal profile settings, where the Message alert tone has changed (Figure 20). To save this change, press Options and then Save (Figure 21). Alternatively, press Back and you will be asked whether you want to Save? Press Yes.
to make it clear in my mind, can u use ur own message tone on this samsung u900 soul?
please please, thanks
Posted on Sep 05, 2008
How can i change the text message alert tone
go to profile menu like... general profile and there will be a message box there change the tone for message.....
Dec 27, 2010 | Samsung SGH-U900 Flipshot Cellular Phone
How do I use my own music for a message alert?
- go to settings
- then phone profiles
- make sure that it is set to normal
-when in normal mode press options and then edit
- it will come up with a incomeing call, message
-select meesage
- it will then come up -melody
-message alert
- select message alert
-press options and then change you will then press change and 1 use effect tone
2 use my alert tone
-select use my own alert tone
problem solved
Jul 10, 2009 | Samsung U900 Soul Cellular Phone
Text message tone
Go to menu,Go to settings,Go to sounds settings,Go to alert sounds,now pick the alert you want to get a tone for. It should ask if you want tone or vibrate, hit tone and scrollt o the tone you want to assign to it. Hope this helps.
Jan 13, 2009 | Samsung SGH-G600 Cellular Phone
Sms text tone
Make sure you change your message alert type to Melody or Melody and Vibration before you get to pick your text alert tones or songs. If I remember correctly, my phone was set to only "Vibration" when i first got it.
Dec 29, 2008 | Samsung U900 Soul Cellular Phone
Change the message tone on samsung g600 and u900
PEOPLE WHO WANT A NOTHER TEXT TONE!
You Can Change The Ringtones Of Messages By Going To
Menu> Settings> Phone Settings> Profiles>Normal> Options> Edit> Press Right Button> Down And Change There!!
Hope It Help Youu =]
Nov 27, 2008 | Cell Phones
On normal nor silent profile no alert coming for incoming calls only
Try restoring the factory settings of your phone!
Go to : SETTINGS then FACTORY SETTINGS.. security code: just type 12345.
If still there is no tone alert, then im sure there is a problem with your phone's buzzer, or it might need to clean the contact of the buzzer insice the board. Just try this....
Kindly rate this up! thank you
Oct 15, 2008 | Samsung U900 Soul Cellular Phone
Set message alert
Press on "OK Menu", "5 Settings and Tools", "4 Sounds Settings", "2 Alert Sounds".
Press "1 TXT Message" and/or "2 Pic-Video Message", then "1 Tone".
Aug 23, 2008 | Samsung SGH-U900 Flipshot Cellular Phone
Message tones on the samsung u900 soul
go to settings, then choose phone settings. In phone settings go to phone profiles, normal is highlighted click options, then edit, then ok. Click the right arrow then go to message alert tone, click on options then change and ok. Go to use my alert tone choose your tone go to options and click down and select then ok. Then job done.
Jul 13, 2008 | Cell Phones
Message sent alert
To remove the sent message alert you have to change your keypad tones to mute. Go to the volume in the keypad tones in the phone profile and change it to mute. Only problem is you can't have keypad tones but they get on my nerves anyway! To stop the tone when you finish a call, go to call settings, all calls, call status tones and take off call end tone.
May 14, 2008 | Samsung U900 Soul Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Samsung U900 Soul Cellular Phone Logo
996 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
