TEDELEX T.V. EC29187 POWER SUPPLY TRIPPING
WHEN COLD SMPS TRIPS, THEN AFTER A WHILE SWITCHES ON. USES A MC 44608P40 IC. IN THE PRIMARY SIDE.
2 Suggested Answers
  • 4234 Answers
SOURCE: Sanyo ST-21G1 dead set
There should be a small valued cap in the primary side (22ufd?) at 250V. Check that. Also, look for other small caps int he range of 2.2ufd with 200V ratings in the same general area.
Dan
Posted on May 07, 2008
  • 8457 Answers
SOURCE: Hi, I have a Tedelex EC29187 Television it have
Ur tv it is taken aparts wright now?Yes.Plug in ur tv to see the problems and take the hard end handle of the screw driver and taps around the vertical deflection ic for cold soldering joints,will require resoldering the ic,if the vertical hold flickers or bounced back to normal.No bounce back vertical hold check all the sorrouding capacitors transistors resistors for dead components parts to be replaced,if all the sorrouding parts are good,than that vertical deflection ic it self it is dead and require replacing.
Posted on May 09, 2011
Ic 44608p40
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name or IC number of your device at its search box.
Power supply regulator schematics to many popular brnd TVs are given.
May 11, 2014 | Samsung Televison & Video
I have problem model TCL-14175 I replace ic 8 pins 44608P40 but still unstable power supply
You've replaced the main system control memory IC, I assumes. If so, an adjustment called, memory initialization, should be done after replacement, or, the newly prepacked IC do not work. If you wish to get more details about this, check this link. http://electronicshelponline.blogspot.com/
Oct 08, 2013 | Samsung Televison & Video
Power supply problam solution
What is the number of regulator IC uses with the power supply to this set? If you wish to get details about how to troubleshoot SMPS power supplies, check this link. There is a recent post about it. Check it.
Mar 21, 2013 | Sharp Televison & Video
I have a tedelex ec29187 with a funny picture. The sides seem to be bend inwards. A guy said they call it a east west problem. Help me with a solution please.
Ity is an East West porblem [Pin-cushion distortion] itself. You ahve to check its pin cushhion circuit to detect faulty component/s.
Apr 12, 2012 | Televison & Video
Hi, I have a Tedelex EC29187 Television it have only a horizontal line in the middle of the screen, I opened it and looked for physical damage around the vertical defflection IC, but it show nothing so...
May 09, 2011 | Televison & Video
Have Ge model 52GW945 tv, it went blank no picture, nothing, I checked fuse its ok what next
Check the swithed mode power supply section. Some sets uses Ics for control the power regulation, while others uses transistors as oscillators and choppers. If the power to the oscillator section of the SMPS is absent, the supply system won't wake up. So many reasons are there. You just check the resistor, usually connected from main DC rectified supply, to energise the oscillator section of the SMPS. In most sets it may be two resistors in serial, usually 270k 1W*2. If any one of this get opened, the power supply will not start up. Check it first and preceed. If the set uses Ic as regulator controller, check the positive supply voltage at the respective pin of the Ic.
Oct 15, 2010 | GE Televison & Video
IC used in the power supply section which links primary and secondary section
This is the SMPS unit which is the main power supply.Please check my profile for a link to service the SMPS.
check this link of mine:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sep 20, 2010 | Sony Televison & Video
STV 2118B Chroma trips with bright horizontal line and power supply switches off. What may be the reason?
the verticle stage is fault, causing the power supply to trip.
check the ic of the verticle stage
the amplifier of the verticle stage not working.
Dec 31, 2009 | Televison & Video
No power
OK disassemble the monitor and visually check for bad components or cold solder here is a couple of examples.3bf0ae5.gifcold solder12cd393.jpeg bad capacitor
Jul 05, 2009 | Dell M992 Monitor
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Electro Med Services...
