My top disc drive wont work - Computers & Internet
    Brigadier General:
  • 5,158 Answers
Cd rom ?
Robert
Posted on Aug 27, 2008
My 4 year old put a gamecube disk in my ps3. i got it out but now the ps3 wont pull the ps3 disks in. how do i fix this problem?
Well your disc drive is out of alignment kind of a hard subject to explain so please dont rate me low. Its more then likely the top of your disc drive is not aligned with the bottom of the disc drive you need them to be aligned so it will take discs in and out. Theres gears on the bottom of the cd drives lid. They meet with gears on the top of the bottom part and if they arent aligned they will not accept disc right. Take it apart and with the cd drive lid pulled up hit eject. This will bring the bottom part of the drive into place. Then just easily lay the top part back down and it needs to be directly from the top not side ways. Then when you have your ps3 cd drive lid on you can try to see if it accepts discs right. If it does your good to go if not you need to mess with it a little more. If you need more help explaining just ask I will try to find you a video showing how to do it.
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
Hi I have a ps3 slim and it just recently stopped ejecting my disks.when I press the eject button the ps3 makes a clicking sound but nothing comes out.but if I turn it off then back on it makes the noise...
He is full of **** trying to scam you. It sounds like your disc drive is out of alignment with the top part of the disc drive so the clicking your hearing is the bottom of your disc drive trying to eject and the top is holding its on as the top has sliding parts that meet perfectly with the bottom part of the disc drive so it sucks the game in and out. You need to open it yourself with a philips head screwdriver you dont have to worry about the motherboard or any other part just take the drive out undo the ribbons connect the drive to the motherboard then it should pop right out. Been awhile since I took a slim apart they dont break as often (yet). From here you should have a metal caseing over the disc drive maybe not with the slim. You pop the metal caseing off the you have a plastic disc drive. Take the top part off maybe requires small phillips screw driver. Since you have a disc in it when you take the lid off hook the cables back to the ps3 motherboard and to the cd drive. Now press eject with the top lid off. Then put the top lid back on and insert a disc it should work. Then just put it back together. Theres a little motherboard on that cd drive do not short it out on anything. You can do this if you cant worst is youll have to buy a new cd drive from the repair shop you mentioned. Then they should charge to much labor to put it back together as you had it apart when you got there. But you should beable to do it if you need help taking it apart just google or youtube slim ps3 disc drive repair or how to take apart slim ps3. Hope this helps if not let me know.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Disc door will not open
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
Disc tray pulled out but repaired it. now x-box wont read any disc
Something's probably wrong with your dvd drive. Send it into Microsoft if it's still under warranty. Otherwise, identify the brand name of the drive (on the label on top of the drive) and find the equivalent drive on amazon or ebay. Once the drive arrives, you'll have to take the motherboard out of your old drive and put it in the new one. That board is keyed to your system's motherboard, so a simple swap won't work on it's own. Put everything back together with the new drive, and it should work fine.
Oct 29, 2009 | Microsoft Xbox 360 Console
Ps3 wont read any game/dvd
there is nothing you can do yourself. the ps3 BD drive is bad and needs to be replaced. your only choice is to replace the drive yourself or call sony.
also are you able to play games from the hard drive? if so your BD drive is defective.
May 31, 2009 | Sony Playstation 3 (PS3) Console
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
My disc drive wont open
if you can view the xbox with the faceplate removed theyres a section you can push in to eject the tray. my theory is your Band has snapped in the drive that ejects the tray
Feb 12, 2009 | Microsoft Xbox 360 Console
Magnet issue?
No the thing on top is supposed to move. It sounds like eather a scratched disc or you need to clean the laser lens on the drive.
Jan 19, 2009 | Microsoft Xbox 360 Console
Cd rom drive does not work! NEEDS ASSISTANCE!
Magnit can damage your Cd drive, maby it is damaged.
Nov 14, 2007 | HP Pavilion (PN153AAR) PC Desktop
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
David Payne
David Payne
