Question about Tomtom GO 300 GPS Receiver
GPS TomTom GO 300 does not retain satellite signal. When I get it, it lasts a minute or two and then disappears.
  • Anonymous Sep 25, 2008
    Have same problems. What shall we do with the downloaded files ??
    Regards
    Per
  • Per Haastrup
    Per Haastrup Sep 25, 2008
    Have same problems. What shall we do with the downloaded file ?
I found a toll free number for TomTom, called and actually got a real person. My computer recognized the TomTom (TomTom home was version 7. something); my TomTom unit had software that was too old and it did not recognize the TomTom home. Catherine in tech support sent me a download to update the software and it worked. Thanks for getting back to me. I am attaching the link for anyone that needs to update software in their TomTom GO 300:
http://download.tomtom.com/sweet/navcore/navcore_7.162.8492.go-go300-go500.cab
Posted on Aug 28, 2008
My tomtom one gps can't get signal
When was the last time you updated the QuickFix of your TomTom? It helps your GPS to find the satellites.
Please, do the following:
1) Install "TomTom Home" software in your computer from www.tomtom.com
2) Start TomTom Home in your computer
3) Plug in the GPS dock to your computer's USB port and place the GPS on the dock. The green light on the bottom right of the GPS should turn ON to indicate that the GPS is getting power from the dock and charging
4) Start your GPS while being in the dock. If the GPS asks "do you want to connect to computer" answer "YES"
5) The TomTom Home software will detect the GPS and check if there are any updates for it. Then you'll be offered updates to install. Some are free, some are not. Be sure you choose to update "QuickFix".
Please, report back if you need further assistance
My ID: alexocuello_
Mar 19, 2010 | Tomtom ONE GPS Receiver
No satellite signal on TomTom
hi save all the maps and info you have to your computer and then wipe/reformat your tom tom and the reload it and update it and you should be right to go. cheers
ps update as often as possible i update mine 2-3 times a week if using it daily.
Oct 02, 2009 | Tomtom ONE 3rd Edition GPS
TomTom slow and sometimes won't configure to satellite
All gps units do not do well trying to find a satellite on the move. You should let your unit locate satellites before you start moving.
Sep 05, 2009 | Tomtom ONE GPS Receiver
Waiting for a valid gps signal
A couple solutions:
1) Make sure the TomTom can "see" the sky well... the GPS satellite waves are rather weak and easily blocked by trees, and anything not a window.
2) Hook up your TomTom to the computer (see details at www.tomtom.com or in the manual)
2b) Do a "sync" and download all updates. One of the updates is a small file that tells the TomTom where the satellites are located this week, and helps it sync up much faster. The longer time between uses, the longer it takes TomTom to find the satellites, and that can takes up to 2-5 minutes sometimes.
That can be frustrating with a car full of people waiting to get going and the driver doesn't want to drive without making sure the TomTom works and is giving valid directions.
Aug 16, 2009 | Tomtom One XL GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
My Tom Tom One takes a long time to pick up a GPS signal (30 to 45 minutes)
You might want to try updating your TomTom through TomTom Home. It loads something called "QuickFix" onto the TomTom, which I guess tells the TomTom where GPS satellites are going to be. I get a fix in about 5-15 seconds if I keep this updated, otherwise it takes a few minutes.
Aug 01, 2009 | Tomtom One XL GPS Receiver
I am not getting satalite signal on my tom tom xl
The most common problem to this is because the TomTom doesn't know it's current location.  It may be that you last used your device a long distance from where you currently are now.  I don't know how long you waited for the gps signal to acquire but it can take up to 10 minutes (even on military aircraft if they don't know current location).
Power it up and press on the signal strength icon.  That will bring up your satellite tracking status.  If it don't look like it's doing anything, then your gps has probably malfunctioned.  If it looks like it's acquiring satellites, then give it a good amount of time (10-15 minutes) to see if it can find your location.  I recommend doing it outside of your vehicle with no satellite obstructions to make the process go faster.
Good Luck
Jun 10, 2009 | Tomtom One XL GPS Receiver
No gps device
Sometimes it can take a TomTom many minutes to obtain satellites. To give it a chance and to test it make sure you have a clear 180 degree view to the south ( that's if you are in the northern hemisphere ) . Its to the north if you are in the southern hemisphere.
So, put the TomTom with it's back facing the equator ( all the GPS satellites are above the equator in an arc ) it's almost straight up in fact but towards the equator.
If you switch on , let it boot up , then tap the screen near the bottom right where you see a bar graph . ( see photo's and finger indicates where to tap position )
The screen will change to another screen and again you should have the bar graph on right hand side with a battery symbol either below or above. once again tap the bar graph and a larger STATUS screen should appear. You should be able to see the TomTom scanning for satellites . Any it receives will be GREY but grey ones are not yet locked on. If any of the bars on the TomTom get a fix or lock on they will turn BLUE . Only when the TomTom has 3 or more BLUE satellites can it present a fix on your location. If none of the bars on the graph ever turn BLUE then you have a faulty TomTom or possibly corrupted data on the SD card. If you get ANY of the bars turn BLUE then it's likely your TomTom is working OK but is just having difficulty locking onto any satellites. You might have to wait a while or move location.
Once the TomTom gets a fix , even if you turn it off then on again it will remember what satellites it was locked onto before so it should not need to scan again and should find the satellites real quick or at least quicker. See photographs below for the 3 stages to go through to check status.
( NOTE : The photograph shows a TomTom ONE v2 but almost all models of TomTom show similar screens ) See last photo where one of the bars is GREY , this shows it's receiving that satellite but it's not strong enough to get a fix from it. The last bar shows the TomTom knows there is a satellite there but currently has no signal from it. The BLUE bars show good reception and fixes on those satellites.
I do hope this helps solve your problem but if not then please revisit this forum and post any questions again and i'll see if I can help.
Please remember to rate my comments and recommendations if you have found them useful at all by clicking on the coloured diamonds on this page.
Aug 10, 2008 | Tomtom GO 300 GPS Receiver
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
292 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
