Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Icemaker not working
Kenmore top freezer, cant find model number. water goes into valve at the rear
right corner but doesn't go up tube to filter and ice maker. How do I check this valve???
  • 55 Answers
Try turning off water- remove valve paying attention as to how it is put together. Disassemble valve-clean out-reassemble- turn on water. The water valve is an ea-vy replacement
Posted on Aug 27, 2008
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Kenmore Side by Side 56563400 Refrigerator no ice
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 25, 2011 | Kenmore Side by Side Refrigerator
Kenmore Side by Side Refrigerator no ice
NOTE: This
Leo Ponder
imufo2
Kenmore 56563400 no ice
NOTE: This
Leo Ponder
imufo2
Sep 25, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ice maker quit making ice. No signal to water solenoid
NOTE: This
Leo Ponder
imufo2
Sep 23, 2011 | Kenmore 56983 Side by Side Refrigerator
I have a kenmore ref. Model 795.7757 with error codes ER IF. The ice maker does not work and the temp inside the ref seems warmer than it should be. The freezer is also not cold enough. Please advice....
NOTE: This
Leo Ponder
imufo2
Sep 22, 2011 | Kenmore Refrigerators
The Ice Maker stopped workingon my Kenmore Trio
NOTE: This
Leo Ponder
imufo2
Sep 20, 2011 | Kenmore Refrigerators
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Jun 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
49 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
