Correct camera settings - Computers & Internet
    Brigadier General:
  • 5,158 Answers
For what cam and what operating system ?
Posted on Aug 27, 2008
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
Can you tell me the correct settings for a vivitar vivicam T532 camera
The "correct" settings depend on the type of photograph you're taking and any effects you might be after. There is no one "correct" setting for all types of photography, otherwise there would be no need for any other settings.
Jan 24, 2011 | Vivitar ViviCam 9325 Digital Camera
I am trying to upload photos onto my computer from my camera, but when I open the program it shows that I have no photos. When I turn on my camera to view to pictures, they are all there. How can I get the...
Often in the cameras Setup menu there is an option to be set that makes the camera behave in one of two ways when it is plugged into the computer.
The setting is usually called USB:
The options are, "Disk Drive" and "Camera".
Disk Drive is what you want, so the camera behaves like a flash disk and shares your pictures with the computer when it is plugged in.
Camera mode, will make your camera behave like a web cam attached to your computer.
Finding this setting will requre the correct Mode the camera is in, (probably Review), and the correct menu, often there are different tabs for camera settings and picture taking settings.
Hope this helps.
Jan 18, 2010 | Samsung i85 Digital Camera
Unable to view moves from the camera on my TV set.
this could be correct as the signal for the Camera LCD screen is now being sent to what ever device is connected on the TV out cable.
ensure your connection is
Camera - TV out
TV - Video in.
ensure that your TV is set to the correct channel or input setting to view the signal from the camera.
Nov 14, 2009 | DXG Technology DXG-565V Flash Media...
Hi, my olympus digital camera FE-310 (1,6 years old) often indicates immediately 'battery empty' even with fresh batteries. I tried out different kinds of batteries, but the problem seems to get worse...
Make sure you have the right kind of batteries. These kinds of cameras can use the batteries very fast if they are not the correct kind recommended by the user manual. Read the user manual.
If the camera works correctly, and takes pictures and movies okay, and still uses batteries quickly, then more than likely, the batteries must be the wrong kind. Never use the cheapest kind of double-A in these cameras.
If you use rechargeable batteries, make sure they are charged fully before using the camera.
Try this: Turn the camera on, make sure that the menu setting for the kind of batteries you have installed is set correctly. If you set the wrong kind of batteries, the problems you are having is a common thing.
Also turn the camera on, then set all the menus to the default settings. Then make sure that the kind of batteries you are using is set in the menu as (if alkaline set it so... If rechargeable, set so ... other options may exist in menus).
Oct 23, 2009 | Cameras
The camera is taking pictures that look pink. All the setting are correct.
which model of camera? Do you have white balance capabilities or custom color settings capabilities? All your settings may be correct, BUT if you have a custom white balance that you do not know about, all you need to do is turn it off.
Oct 06, 2009 | Canon PowerShot A95 Digital Camera
My camera doesnt work n my phone hangs when i use camera
Try checking on your camera settings to verify if all the settings are correct. If you don't know how, bring phone to a store and have them troubleshooted it for u. So they can verify for you if phone itself needs to be replaced or just the camera settings needed to corrected
Aug 11, 2009 | Motorola Mobility SLVR L7 Cellular Phone
All my photos came out blue from my E-500 Olympus
It sounds as if you accidently hit the button for custom white balance setting. It is very easy to do with this camera as this button is located close to the shutter button.
Turn the camera mode dial to the P mode setting. Go to the Menu. Go to the camera 1 tab and then right arrow over and then down arrow to custom reset setting. Right arrow over and highlight reset and press ok. Highlight Yes and press ok. This will reset the camera back to factory settings and should remove the blue from your images.
Apr 05, 2009 | Olympus EVOLT E-500 Digital Camera
Nikon D100 Manual shooting help
The mode dial (topside left) must be set to M. That's it for manual settings - the camera won't check anything, and certainly shouldn't require the flash. You need to choose your own shutter speed and aperture settings to get a good photo, but the camera will let you take a picture no matter how you have it set.
Feb 01, 2009 | Nikon D100 Digital Camera
Blurry pictures
Adobe photoshop might help.
Apr 06, 2008 | Casio Exilim EX-S600 Digital Camera
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
