Question about Toshiba Satellite A55-S106 Notebook
Won't start booting
I'm trying to upgrade a faulty HD for a friend. Originally he hit his lappy (the Toshiba this board is for) and it started booting Windows but wouldn't get past the Windows loading screen (started reseting) and wouldn't get into safe-mode. I thought it might be a corrupted HD, but when I was running a surface scan he got impatient and stopped it close to the beginning of phase 4 (of windows' scandisk running in an enclosure). Then it stopped booting at all and there are now hundreds of corrupt sectors (I really shouldn't let this guy own a computer. :) ).
So I formatted an old HD of mine and stuck it in his lappy to try and install XP Home. Problem is, when I formatted it, it didn't clear the boot sector and GRUB was throwing an error because it couldn't find the partition tables. Since this is still technically a valid boot disk, his lappy wouldn't try to boot from the CD. So I had to use another laptop to install XP Home onto that hard drive since I couldn't figure out how to change the boot order on his. After the installer made the HD bootable I stopped it and put this HD into his laptop again. Now it won't boot to anything. It will recognize that Windows didn't boot properly on the previous load, but even after saying "start Windows normally" (and it works fine at this screen) and waiting 5 minutes, nothing happens. What might be causing this problem?
I should mention that the fan is NOT turning at any point during this. I think it might be broken because I can't feel or hear air moving inside other than the HD and the CD drive.
  • nfitc1 Aug 27, 2008
    I think I need to add that the HD I'm trying to upgrade to is an 80GB Toshiba brand HD. I don't know if that's significant, but I'd better not leave anything out.
  • nfitc1 Sep 03, 2008
    This can now be disregarded. It was a software error. Apparently I can't begin an installation of XP on one computer and continue it on another.
    I learned something new. :)
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
23
Posted on Jul 25, 2009
I have a T430s originally come with Windows 7, then upgraded to Windows 8 Pro. I was trying to recover using the recovery media dics, and it booted without problem, but it says Recover Fail once I started...
Well sounds like you bought an upgrade disc rather then full install? but try hitting F8 right after the boot screen and you should get windows options..... try the windows restore one
Oct 04, 2013 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Laptop won't start up at all
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 04, 2012 | Toshiba Satellite A305-S6839 Notebook
Toshiba won't boot up
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 10, 2012 | Toshiba Satellite U405-S2826 Laptop
I have a toshiba protege 7100 series and it won't boot past the windows screen
Try hitting F8 during startup and choose last known good configuration.
Or you could try starting in safe mode and doing a system restore.
Have you made any changes to the system prior to this problem, as sometimes installing programs/drivers can cause similar issues. If so you will need to remove or configure the program causing the conflict. You can do this in safe mode.
Mar 13, 2012 | Toshiba Portege 7100 Notebook
My Laptop is Satellite L505-S5990,After i change boot sequence from booting with CD rom to HD it won't effect changes.WHy is it this way>Any tips as to why it is so and how i can change boot...
Changing boot sequence.
Go to bios setting, click "F2" upon start up( when you read the bios and HD readout ). Choose the part boot sequence, click " enter" and choose what drive will be use first.
Save the settings upon exit.
Hope FixYa helped you out!
Aug 17, 2011 | Toshiba Satellite Laptop with Intel Core 2...
Not able to recover windows on toshiba l300
You need to get disk for Vista from anyone and then use your windows product key mentioned on the sticker on back of your Toshiba Laptop to install Vista again on your computer. But as you had already formatted it so all data is lost now.
Jun 01, 2010 | Toshiba Satellite Pro L300 Notebook
Upgrading VAIO laptop HDD
get a lappy external caddy that is powered by usb place new harddrive in it. download a copy of hirens sorry dont have the link or use norton ghost ifyou have that boot lappy to os then load cd norton ghost or hirens.hirens has multiple software to disk copy simple and user friendlyso hirens is you best bet. after disk copy swap lappy drive around. send lappy model if you dont know how to install new harddrive i'll loook up to hirensfor you but you could try it was easy to find the last time i got it.
Apr 13, 2008 | Sony VAIO VGN-S460 Notebook
Booting problem
Sounds like you have a "loose connection" in your lappy, thats NOT acceptable with a new unit. I suggest ya take it back to the shop and quietly "read em the riot act"... and get replacement or repair...... A repacement would be the most desireable outcome, as far as I would be concerned, Claiming under the "Manufacturers Defect" side of things. One should NOT have to "Hit" any device to make it work.. more so when new!
Aug 28, 2007 | Toshiba Satellite A100-ST3211 Notebook
Computers & Internet Logo
133 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
