Question about Toshiba e740 Pocket PC
Backup and restore data
How do I backup and restore data on my Toshiba Pocket PC e740?
    Master:
  • 903 Answers
Section A - How to use a Toshiba Pocket PC e740 without loss of data: Never let the battery fully discharge. Never disconnect the battery from the e740. Regularly backup your stored data. Always connect the product to an external power source before changing the battery. Section B – How to backup your data: B1 – Using Activesync You can make a backup of the Toshiba Pocket PC e740 data to your notebook or desktop computer. If you have backed up your data to your notebook or desktop you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data please DO NOT remove the Pocket PC e740 from the USB cradle and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instructions: Insert the Toshiba Pocket PC e740 into the USB cradle. A connection between the e740 and your notebook or desktop will be established. Please close all active applications on the e740. On your notebook or desktop start Activesync and select Tools and then Backup/Restore. Select Full Backup. Select Back Up Now to start the backup process. B2 – Using a Compact Flash (CF) or Secure Digital (SD) Memory Card: a) How to insert a Compact Flash Memory Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Confirm the direction of the Compact Flash memory card by lining up the side grooves of the card and groove edge of the card slot. Insert the card smoothly and completely. b) How to insert a Secure Digital Card: Ensure the e740 is connected to the mains. Turn the e740 off. Remove the dummy card if necessary. Insert the Secure Digital card with it’s contact surface (the metal contacts) facing the back of Toshiba Pocket PC e740. Press the card down until it clicks. You can make a backup of the Toshiba Pocket PC e740 data to your Compact Flash or Secure Digital memory card. If you have backed up your data to your Compact Flash or Secure Digital memory card you can restore that data to your Toshiba Pocket PC e740. Periodical data backup is recommended. The following types of data can be backed up: FILE: Includes files created by Pocket Word, Pocket Excel, Notes etc. or an additionally installed program. REGISTRY: Setup information of Windows or programs. DATABASE: Database information from Pocket Outlook. When making a backup or restoring data using the DataBackup program please DO NOT remove the Compact Flash or Secure Digital card from the Pocket PC e740 and DO NOT turn off the power to the device until the backup or restore is completed. Backup Instr
Posted on Sep 07, 2005
How do I prevent loosing data when my battery discharges
Hi. Actually, on pocket pcs there's a backup battery onboard, but in your case maybe backup battery is dead. So you can have that changed or you can charge your PDA on regular basis. Hope this helps.
Jun 28, 2009 | Toshiba e355 Pocket PC
Restoring Backup to New Axim
The backup utility included on your Dell Handheld will backup your data to a storage card. You can restore on your replacement handheld from that storage card. From your Host PC, you can go to Tools | Backup/Restore and do a backup to the Host PC, and you can then restore after syncing the replacement handheld for the first time.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Problem with mail
My problem was that the Folder which I tried to open contains a damaged File. My solution was after restoring the backup, to synchronize the mail with my desktop computer and checked the content of my mails.
Sep 08, 2005 | Toshiba e740 Pocket PC
Memory loss
the problem is based on a failure of the backup accu. This can only be fixed by a Toshiba Repair Service. They have to change a Board inside the PDA.
Battery problem?
the problem is based on the backup battery and the Battery charging Electronic of the Pda. The only chance for you is to contact a Toshiba Service Partner for a repair of the Pocket PC. The Mainboard of the PDA has to be replaced.
Reset my Pocket PC
A Reset of your Pocket PC is equivalent to "Restart" of a desktop computer. Carry out the Reset only in such unusual cases as when a button or tapping the screen does not respond. When your Pocket PC is reset, no data will be deleted. All stored information like Addresses, Contacts, Tasks or Programs are still stored in the Pocket PC memory. To Reset the Pocket PC, the power must be on. Then press the Reset switch with the stylus, then release. Your Pocket PC should function properly thereafter. If the functions cannot be restored, even after the reset button is pressed, Initialise your Pocket PC (refer to the FAQ article: How can I initialise my Pocket PC (Factory Reset). If you have further questions, please refer to the Instruction Manual page 12-4 (172 of 182).
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e740 Pocket PC Logo
270 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
