Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
Will not power down, bios code 7F,
When i go to power down computer i have to unplug the cord from power supply .When i replug the cord it powers up without me hitting power button.Bios code 7F. thank you john
    President:
  • 2,961 Answers
You need to check the mobo front panel PWR and RESETconnections as they must be wrong if youve connected them yourself
Posted on Aug 27, 2008
Windows has stopped this device because it has reported problems. (Code 43)
(laptop) unplug the power cord, then take out the battery, unplug all usb devices, leave it alone for a minute or two and then replug the power cord and then the battery. Turn the computer on and restart as normal. replug in your usb devices and they will reinstall as usual
Aug 13, 2013 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
The computer won't turn on
You could be having any of several problems.
First double check to make sure no cords came loose - you may even want to unplug and replug the power cable both out of the computer and the wall.
If you do not have a loose cord, listen closely when you attempt to turn the computer on - is it making any noise? Do any lights come on? If not, you likely have a bad power supply.
If the computer does come to life, just no reaction on the screen, make sure your monitor is plugged in and turned on, and try unplugging and replugging the cord connecting the computer and the monitor.
If this still does not get it, you may be dealing with either a graphics card or monitor problem. If you have an alternate plug for the monitor to go - try that, or if you have a different monitor to use, try that.
This should either greatly narrow down or fix the problem for you.
Aug 24, 2011 | Computers & Internet
Device cannot be recognized error code 43 Problem....what does it mean?
Try this, on a laptop, unplug the power cord, then take out the battery, unplug all usb devices, leave it alone for a minute or two and then replug the power cord and then the battery. Turn the computer on and restart as normal. replug in your usb devices and they will reinstall as usual.
Jun 13, 2011 | Computers & Internet
Won't power up-- suppply OK
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button.
Try to boot the pc.
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker, put the powersupply in a different pc, or try a different powersupply in the problem computer.
Jul 06, 2009 | Acer Aspire L100 PC Desktop
Errore codeoxe0000227
Try to boot the pc.
Could be bad ram, motherboard, cpu, powersupply, videocard.
Jul 06, 2009 | ASUS P5P800-MX Motherboard
Screen went dead, unplugged the graphics card and
Try to boot the pc.
If the video card is suspected to be damaged, try it in a other pc (friend's, mom's or dad's, pentagons' ).
if it is bad, there is your answer.
Jul 06, 2009 | XFX Computers & Internet
Flashing orange light on front of my dell 5150 desktop, will not turn on, even after unplugging for one hour. when plugged back in, flashes orange, no fan, no power. JK
Try to boot the pc.
Jul 05, 2009 | Dell Computers & Internet
My dell desktop is just making a ticking noise and won't turn on
If it is beep sound the problem may be with the Ram. Remove the ram and refix it. If the problem not solved replace the ram
Jun 30, 2009 | Dell Dimension 4600 PC Desktop
Dell Laptop power supply charges sporadically
when i replug my Dell laptop ,the charging system does not display.
Mar 13, 2009 | Dell HQRP Replacement Laptop AC Adapter /...
I HAVE A COMPUTER WITH CONFIGURATION OF INTEL EXTREME DP45SG MOTHERBOARD,QUAD CORE 6600 PROCESSOR,NVIDIA GRAPHIC CARD,DDR3 RAM(1333 HZ),500GB HDD(SEAGATE) and still my compuer screen shows NO DISPLAY...
Try to boot the pc.
Ok try all this first...
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
279 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
