Question about HP Office Equipment & Supplies
Are there any known problems with the compatibility of the Brother HL 4040CN and Vista?
Posted on Aug 27, 2008
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
Why is my hp officejet only printing 1/4 page from copier? It prints fine from the computer.
Not enough information.
What printer model?
While scanning and copying?
Try resetting your printer to manufacturer defaults and try again.
Aug 06, 2014 | HP OfficeJet Office Equipment & Supplies
Printer stops in middle print job
What model is this printer? If it has a scanner/copier function, try copying something and see if it works that way. If it does, there is an issue with the computer. If it has a problem copying, it is a problem with the printer. Let me know and I can give you additional steps to take.
Jan 07, 2014 | Dell Office Equipment & Supplies
Printing issue
If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
Sep 13, 2009 | Canon ImageRUNNER 330s Copier
Printer does not print when I send from my computer, but does print when I place copy under screen for copying.
Copying and printing are two different functions. Your machine will process copies because the work is all done AT the copier. In order to print the PC and the copier need to be able to communicate properly.
Make sure that the printer drivers for your machine are set up properly on your PC and the two systems are communicating correctly.
Aug 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing to copier
ah, probably it means that the department ID is activated on your copier.
go to the printing preferences on of the panasonic dp-4530 on your pc, the click the job type tab.
on the space provided you may type in the code that you use during copying or ask the person incharge on your company re department code.
Aug 18, 2008 | Panasonic Workio DP-4530 Copier
Scanning aspect of the Di3010
First of all the ftp server settings need to be turned off. One touch scanning will only go to the clients computers if the software is activated. If you want it to go to the ftp server, the one touch scanner can't be used.
It's one or the other.
I'm certified and work on this line on a full time with many clients.
If this doesn't reslove the problem, let me know and I'll make you a video on how it works.
Jul 20, 2008 | Minolta Di3010 Copier
How to enlarge print on copier
To enlarge or reduce a printed document by specifying a percentage, select 'Scaled Printing'.
Access the printing preferences by opening the printer Properties/ Preferences.Click here and follow instructions in this document.
Mar 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
1. Check the toner cartridge and be sure nothing is blocking the ink flow.
2. The drum cartrudge may also have something on it blocking the laser light from getting to it.
3. There may be something in the laser window blocking part of the light path.
4 Something in the scanner blocking the image.
5. A defective scanner, yes even if new.
Feb 22, 2008 | Sharp AL-1655CS Laser Printer
Printing only one quarter of page when copying
Make sure by checking if your lamp scanner light when your doing a copy ??? This look like a scanner problem !
Make sure to that your glass is clean !
Feb 07, 2008 | Epson Stylus CX4600 All-In-One InkJet...
20 people viewed this question
Ben Johnson
