Question about Hotpoint Aquarius WF220 Front Load Washer
Trying to fit new belt
Hotpoint washer WF320P
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Loop round the motor first then up around the pulley, this will be tight so pull halfway round and hold it to the pulley while turning it, rather like refitting a bicycle chain. make sure it runs cetrally on the pulley by adjusting it on the motor shafts grooves.
Posted on Jan 28, 2009
I want to know how to fit a new belt to a hotpoint washer/dryer wd865
Remove the rear panel of washer, and tilt washer forward away from you with someone to hold it steady.
Fit the belt round the motor pulley first and slowly feed it round the drum pulley turning the drum pulley at the same time,
It will be very tight, so watch your fingers.
It may seem to be too small, but persist with it, and it will go on.
Nov 12, 2010 | Hotpoint Ultima WF865 Front Load Washer
Drive belt came off spindle on Hotpoint First Edition Washing Machine.Have tried to replace but back of machine does not remove, just a small access hole. How can I refit a new belt please??? John Bennett...
Remove rear panel, remove top cover,.tilt washer forwards, get someone to hold it for you, and fit belt round motor pulley first, then start feeding it round drum pulley, easing drum round at same time, it will be tight, so watch you fingers,
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint First Edition FEW12 Front Load...
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Belt on a hotpoint wf250
open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Apr 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Fitting new brushes on a hotpoint washing machine
Remove lower rear panel.remove drive belt, undo screws that secure motor. unplug motor lead, noting which way it is fitted.,lever motor back and remove, replace brushes and refit motor and belt.
Mar 30, 2008 | Hotpoint First Edition FEW10P Front Load...
Belt fitting for a WF000 hotpoint washer?
It should go around 2 wheels; one is the pulley of the motor, where there is a good groove. The other goes around the tub wheel which is big one. First fit to the motor wheel then fit to one side of this big wheel & turn the wheel to engage it gently. The belt should have a "give" of only half an inch, or it will be too loose or too tight.
If helped pl rate.........
Dec 28, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
117 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
