Question about Hotpoint Aquarius WF220 Front Load Washer
Wf220 how do i get the old bearings out of the drum, with out a bearing puller(cant find one) seems impossible.
    President:
  • 1,462 Answers
Belt them out with a cold chisel - this is a brutal job
Posted on Oct 02, 2008
Bearings drum
Replace the bearings.... the only solution the machine will have a new lease on life.
May 27, 2013 | Hotpoint Aquarius WF220 Front Load Washer
Hi, How do i remove the two drum barings i,ve tried drifting from the back of thr drum but it won,t budge a millimetre?
Not an easy job. The whole tub needs removed from the machine. And if possible the tub needs split in 2, this gives access to the inner bearing. The bearings need to be removed using bearing pullers. If the tub cant be split then you will need to replace the tub. Would advise getting a professional to carry out the work.
Mar 02, 2011 | Hotpoint Washing Machines
Hotpoint WF220P has become very noisy during spin, especially at high revs. Can it be worn brushes or motor, or bearings? Otherwise all is OK.
Remove drive belt, and spin drum by hand, if it feels rough or noisy, then the main drum bearings are worn.
If no noise from drum, could be a motor prob.
Please rate ,my solution.
Thanks.
Nov 02, 2009 | Hotpoint Aquarius WF220 Front Load Washer
I need to remove the bearings from the drum of my washing machine how do i do it
Its not impossible but a real battle without the correct tools. If at the back of your washer, you have the main arm assembly, then firstly remove the belt and then the pulley.Undo the nuts holding the assembly and in short, pull that assembly off by pulling it towards yourself. Once off, you will see the bearings and seal that need to be replaced. Once done, reassemble carefully and god luck.
Sep 23, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Noisy bearing in a maxx wfr 2860
they can be a pig but if you know whot you are doing you can do it in a few hrs just make sure you mark any wires that you take off it help when you put the washer back if you are not useing a press to put the new bearings in use your old ones to tap your new ones in place dont hit then to are or you can damage them hope this helps and good luck
Jun 28, 2009 | Washing Machines
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
161 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
